Brake Caliper Dust Seals And Retaining Rings
10 replies to this topic
#1 The_Doc
The_Doc
  • 20 posts
  • Local Club: www.dcmoc.co.uk
Posted 18 February 2025 - 09:43 PM
What...the...hell. These are ridiculous. What sadistic mother f'er thought this was a good solution. I'm so close to throwing perfectly good calipers in the bin and buying recon units. How is it possible to fit new dust seals on 8.4 calipers. I just cannot do it.
#2 Gaz66
Gaz66
  • 840 posts
Posted 18 February 2025 - 09:57 PM
My last set of S discs I refurbed didn't get them fitted.
#3 68+86auto
68+86auto
  • 797 posts
  • Local Club: Queensland Mini Car Club
Posted 19 February 2025 - 12:50 AM
Use a block of wood.
#4 The_Doc
The_Doc
  • 20 posts
Posted 19 February 2025 - 07:34 AM
Tried that. Did a great job of crushing the retaining ring into a tangled mess!
Eventually I managed fit on old ring which had a very slight kink in it. I then managed to straighten it back out once in place.
Without splitting the calipers I can't see how it can be done
#5 timmy850
timmy850
  • 3,237 posts
  • Local Club: MITG
Posted 19 February 2025 - 09:39 AM
I just split the calipers and put in new seals
If you take the seals to the hardware shop you may find a bit of pcv pipe the right size to get them in
#6 Cooperman
  • 23,208 posts
Posted 19 February 2025 - 10:35 AM
Having had this issue over many years, I now always split the callipers. Then I put a smear of light grease on the edge of the outer seal and press it in slowly using a flat piece of wood. It's still a b****r of a job though.
After splitting the callipers, fit a new O-ring and torque the bolts to 45 ft, lbs. using a bit of Loctite.
#7 The_Doc
The_Doc
  • 20 posts
Posted 19 February 2025 - 10:40 AM
Thanks, that's what I'll do next time!
#8 slidehammer
slidehammer
  • 1,177 posts
  • Local Club: LSMOC
Posted 19 February 2025 - 05:12 PM
Last time I did it the old rings went in fine but the new ones that can with the seals were a complete pain. I gently deburred / chamfered the edges before winding them in with a piece of wood.
#9 Spider
  • 14,701 posts
Posted 19 February 2025 - 05:39 PM
They are a very neat fit. I've always split the calipers, I feel it's the only way they can be properly cleaned in any case.
Ideally, they need a lead in to get them in.
#10 Lplus
Lplus
  • 841 posts
Posted 19 February 2025 - 07:51 PM
This - they seem to be made with  sharp edge that jams in the recess.  Getting all the corrosion out of the recess is vital too.
#11 nicklouse
  • 18,436 posts
Posted 19 February 2025 - 08:55 PM
I found a brake pad spreader worked well.
