Vin Number Verification.
Posted 16 February 2025 - 07:19 PM
It's an Automatic.Would this be the correct vin. Thankyou.
Posted 16 February 2025 - 09:17 PM
In the book, Factory-Original Mini by James Taylor it indicates that the range of serial numbers for a Mk2 is between M-A2S6-507001 and M-A2S6-714811. I believe, but can’t be certain, that only the engine number would indicate that the car is an auto and would contain an ‘A’ as a variant identifier.
Posted 16 February 2025 - 11:34 PM
See the 'Classic Mini Chassis/VIN Decoder' in link below:-
https://www.minimani...sed_#1959to1969
You may also find the 'Automatic Mini Register' in link below a useful source of information:-
https://autominiregi....proboards.com/
Edited by mab01uk, 16 February 2025 - 11:37 PM.
Posted 17 February 2025 - 07:38 AM
Hi all, I have a 1968 Morris mini .I can just about make out the vin number as the plate is rather corroded. I think it reads M/ A2S4 S xxxxxx M
Top tip, it is often easier to read the rear.
I guess it is not a UK built car.
Posted 17 February 2025 - 08:39 AM
Posted 17 February 2025 - 09:56 AM
Was it made in NZ or was it made in Aus?
I don't know the NZ numbering but YMA2S4 is a number for a matic in Australia.
Posted 17 February 2025 - 10:35 AM
Hi, what do you mean read the rear?
I assume he means take the plate off and look at the stamped impressions from the back side where there is less rust and grot
but I may be wrong
Posted 17 February 2025 - 02:28 PM
Hi,
The other way to get a clearer reading of the number is to cover it with masking tap and then little rub it with a pencil and that should highlight the numbers and letters.
Paddy
Posted 17 February 2025 - 03:08 PM
UK registration documents have the chassis/VIN number on them and you can also find the VIN number using the vehicle registration number on some HPI type searches....not sure about other countries systems.
Edited by mab01uk, 17 February 2025 - 08:30 PM.
