Loud Clunks Bangs And Knocks In Steering. Help & Advice Sought.
9 replies to this topic
#1 DClarke1954
DClarke1954
  • 34 posts
  • Local Club: Essex Mini Club
Posted 16 February 2025 - 03:04 PM
The car is new to me (3 months) and has not been running for a while (issues).
I have now got it running (new dizzy, carb rebuild) and it now runs (with a few farts, pop's & bangs in the inlet occasionally when I take my foot off the throttle after an uphill climb).
While out trying to see if the ignition/fuelling changes have had the desired effect I notice a lot of unwelcome noise on low (crawling speed) turns.
The car has Hi-los, camber adjusters etc. but it almost feels like something is snagging somewhere on hard L-R or R-L turns.
You can feel it through the steering and indeed the floorpan.  Heaven forbid if something should come apart while at speed.
Of course if I put it up on stands then there will be no load on the suspension/steering to resist any turning effort/input and it may not do it at all.
Is it common for classics to have such issues when they have been "altered" from factory standard?  Are there any common problems/issues?
Thanks in Advance.
Dan.
#2 mab01uk
mab01uk
  • 12,327 posts
Posted 16 February 2025 - 03:17 PM
What size wheels/tyres are fitted, as some wider rims with increased offset and wider tyres can rub/make contact with the inner wheel arch on full steering lock. Especially 13" wheels which had restrictors fitted to the steering rack to prevent this happening when the 13" wheels were factory fitted on the later MPi Minis.
The problem is also worse on harder cornering when the suspension is more compressed under load reducing any clearance to any wheel arch extensions and/or the front wings leading edge where they have been cut back for more tyre clearance.
If this is the problem there may be rub marks on the inner wheel arches, also put the steering on full lock in both directions and have a look to see how much clearance there is before contact when stationary on each side.
On lowered suspension Minis some disc brake calipers can also start touching on the tie bar on full lock if steering rack is not limited....
Worn driveshaft CV joints can also make a knocking noise during low speed turns on full steering lock.
KAD Mini Steering Rack Limiter Kit:-
https://kentautodeve...ack-limiter-kit
Edited by mab01uk, 16 February 2025 - 03:30 PM.
#3 DClarke1954
DClarke1954
  • 34 posts
Posted 16 February 2025 - 04:07 PM
Thank you for the pointers, I have some things to look at now.
It has had a 10-inch wheel conversion and there are brand-new Yokohama A008 165/10 tyres on it.
I will put it up on stands and have a look at how much clearance there is in the "tight-spot" areas.
#4 Ethel
  • 25,853 posts
Posted 16 February 2025 - 05:13 PM
You won't get a proper look on stands as the suspension will be unloaded & the wheels lower.
There are plenty of possibilities  but jacking it up & levering stuff should enable you to check most of the rubber bits for excess play - engine mounts & steady bushes, subframe mountings, tie rod & bottom arm bushes, damper mountings.
#5 DClarke1954
DClarke1954
  • 34 posts
Posted 16 February 2025 - 10:14 PM
I need a friend with a "pit" to put the car over and go lock-to-lock perhaps, that might get to the root of the problem.  Especially if I put the front wheels on castors.
Edited by DClarke1954, 16 February 2025 - 10:15 PM.
#6 Homersimpson
Homersimpson
  • 824 posts
Posted 16 February 2025 - 10:57 PM
I would also check the following:
1. Are the steering rack u bolts tight (accessed from inside the car under the front carpet).
2. Is the steering rack under strain, if a steering column lowering bracket has been fitted the rack should have been loosened but some times people don't do this which can cause issues.
3. Are the front subframe rear mountings ok, if these fail or become weak they can cause a lot of movement.
4. Where the front subframe rear mounts bolt to the toe board, is the metal ok as they can crack in this location, especially if solid mounts have been fitted.
5. Is the top engine stabiliser to the bulkhead ok, the bushes can go but also the bulkhead bracket can fail.
#7 Ethel
  • 25,853 posts
Posted 16 February 2025 - 11:28 PM
If the tyres are fouling they'll very likely be some evidence of it where they rub.
Is there any particular circumstance that causes it, or makes it more pronounced? Braking, accelerating, steering in any particular direction, bumps in the road, reversing?
#8 DClarke1954
DClarke1954
  • 34 posts
Posted 17 February 2025 - 05:26 PM
I don't need to do anything extreme to hear/feel this interference.   E.g. just turning left in my street onto my driveway a bit tight can provoke it.
#9 Chris1275gt
Chris1275gt
  • 912 posts
Posted 17 February 2025 - 06:20 PM
Has it got cv joints on it which may have gone kaput they clank about at low speeds left or right.
#10 mini-mad-mark
mini-mad-mark
  • 846 posts
  • Local Club: northants wot no brakes
Posted 20 February 2025 - 11:22 PM
You are not having much luck with this mini !!! that you were "lucky" to win in the competition?
I've entered the same competition a few times and whilst I've never read the small print I assume it has some kind of disclaimer about the condition of the mini you might win - i.e. it may or may not be completely fault free even though the bumph usually points out all the good things about the cars offered as prizes - and the person offering them may or may not actually be aware of any faults that might be present.
Just a thing to think about (but it wouldn't stop me entering occasionally as I have done)
Direct answer to this point I agree with others you need to look at wheel arch clearance  - Try it in reverse and if it sounds worse than that is almost certainly the cause (but be careful you don't rip off an arch as the contact might be very heavy in reverse)
