My ‘98 JDM Mini has an Mpi block with Spi injection, but no dizzy. Would the camshaft therefore be an Mpi camshaft?
1998 Jdm Camshaft
Bobbins
, Feb 14 2025 10:42 PM
4 replies to this topic
Posted 14 February 2025 - 10:42 PM
Posted 15 February 2025 - 12:19 PM
Does it have a cam sensor fitted? That’ll be the giveaway, only really difference on the cams other than the dizzy drive which your block won’t have if it’s MPi casting
Posted 15 February 2025 - 04:53 PM
No cam sensor in my 98 JDM SPI(MPI block).
Posted 16 February 2025 - 08:25 AM
Is the cam sensor internal to the block or is it obvious from the outside? I’m in tne process of stripping the engine but haven’t got to the cam yet.
Posted 16 February 2025 - 10:04 PM
It’s where the mechanical fuel pump is on earlier blocks, nsr of the block, bolted on external so you’ll see if it’s there or not.
