Correct Supercharger Tensioner
10 replies to this topic
#1 Royalasaforce
Royalasaforce
  • 82 posts
Posted 11 February 2025 - 06:36 PM
Finally got round to bolting up the supercharger today and fitting the bottom pulley. The tensioner supplied is a bit whack and I’m not sure if it’s meant to be this way but where it is in the picture it’s pretty much fouling the vent and close to where the lower rad hose will be going.
https://ibb.co/XxSjWfF0
#2 Homersimpson
Homersimpson
  • 829 posts
Posted 12 February 2025 - 09:11 PM
I've not seen one of these before but just looking at picture can the rear section of the belt not run over the pulley with the front running straight?
#3 DeadSquare
DeadSquare
  • 3,089 posts
Posted 13 February 2025 - 11:34 AM
That all looks wrong to me, but my supercharging was all done with a sliding-vane Shorrock
Edited by DeadSquare, 14 February 2025 - 10:01 AM.
#4 stuart bowes
stuart bowes
  • 2,095 posts
Posted 13 February 2025 - 01:22 PM
what's actually holding that pulley at the right angle?  is it just friction from the tightness of the single bolt?
#5 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 13 February 2025 - 02:40 PM
Yep!
#6 Royalasaforce
Royalasaforce
  • 82 posts
Posted 13 February 2025 - 04:40 PM
Yeah just didn’t look right to me either hence the post. Should the supercharger be rotating clock or anti clockwise?
Having the back going over the tensioner first is somewhat similar maybe a little better but still very tight.
I really don’t like the tensioner that was supplied I know they need some form of actual tensioner like a spring to keep tension ( this will just loosen and need adjusting constantly.
It’s a m45 from the r53 mini. What tensioners do you guys have? I couldn’t find any apart from factory tensioners
#7 Royalasaforce
Royalasaforce
  • 82 posts
Posted 13 February 2025 - 04:43 PM
And would I need some way of reversing rotation if it’s spinning backwards? Not sure how that would work without major fabrication and gears
#8 DeadSquare
DeadSquare
  • 3,089 posts
Posted 13 February 2025 - 05:27 PM
My apology, I got that wrong, I was thinking of my old Shorrock supercharger.
Edited by DeadSquare, 14 February 2025 - 09:56 AM.
#9 Royalasaforce
Royalasaforce
  • 82 posts
Posted 17 February 2025 - 08:10 PM
Haha it’s all good. Hope to figure it out on my next 4 off. Any of you wouldn’t have any recommendations on best set up for a distributor, I’ve got the csi 16 program dizzy so can have a fair range of variance
#10 timmy850
timmy850
  • 3,319 posts
  • Local Club: MITG
Posted 18 February 2025 - 04:43 AM
That’s just one of the “less than optimum” things about that supercharger kit. You can get a spring loaded belt tensioner, but then you’ll need to make up a bracket to fit it somewhere
It looks like the more recent kits used a smaller diameter pulley
https://vmaxscart.com/
Something like a 123 programmable distributor would be a good idea, as you can program to retard the timing under boost. There are also many other options with trigger wheels and fully mappable ignition curves vs rpm and load
https://www.123ignit...J4KUlRucRDxsSLM
#11 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 19 February 2025 - 10:28 AM
Here's mine from VMAX
  • Attached File  1.JPG   72.47K   3 downloads
