Wiring diagrams here
https://www.theminif...agrams-redrawn/
The ROVER MINI WIRING DIAGRAM MINI CLUBMAN, ESATE AND 1275GT 1976-ON PAGE 86-7.PDF diagram is the only clubman one that I can see with reference to orange. The purple/orange (PO) runs from the hazard light unit (flasher relay) to the interior light. See fuse info below. The light green & orange (LGO) runs from fuse block terminal 6 to the wiper motor, the washer/wiper switch & the heater switch.
Fuse info sounds like this below which is from this thread. PO wire looks like a 10A fuse.
https://www.theminif...s-covered-data/
Main fuses (four-fuse fuse block - later models)
Fuse connecting Rating (amp) Circuits protected
1 and 2 35amp Stop lights, reversing lights, direction indicator relay, heated rear window, headlight dim-dip relay. These systems will only operate with the ignition switch at position ll
3 and 4 25amp Horn, headlight flasher, brake failure circuit, radio memory. These systems operate independently of the ignition switch
5 and 6 25amp Heater blower motor, windscreen wipers/ washers, instruments. These systems will operate with the ignition switch at position I or ll
7 and 8 15amp Left Hand side and tail lights, instrument panel lights, headlight dim-dip relay
Note: The fitting of additional accessories which are required to operate independently of the ignition circuit should be connected to the “4” terminal
Line fuses (four-fuse fuse block - later models)
15 amp Right-hand side and tail lights
10 amp Direction indicators/hazard flashers, interior light
15 amp Dim-dip lighting
10 amp Rear fog light
Edited by humph, 06 February 2025 - 07:33 PM.
