I've a hell of a rattle that goes when the clutch pedal is pushed in a small bit when in neutral engine running. Suspect it may be clutch release bearing.
Seeing as I am going to be in that area of the engine/box and the clutch is slipping a lot, and the jiggle pin at the bottom of the casing is dripping oil a lot, I was going to replace the clutch.
Engine was re-built in 2012 to accommodate supercharger with new clutch, so assume its had enough abuse!
Question is: engine out or leave in and work around it to replace bearing/clutch and other sundries along the way?
