I was getting ready to spray Wayoyl down through the A pillars and discovered a block of foam stuffed in the top of the right side post. If this was a factory thing it sure was a stupid factory idea.
Do you guys recommend putting it back in for reason I'm missing? It seems like it would be a moisture trap. And probably caused the roof to rot out on the car I'm doing now.
You thoughts are appreciated.
Bill
A Pillar Foam
Aridgerunner
, Feb 04 2025 04:57 PM
4 replies to this topic
Posted 04 February 2025 - 04:57 PM
Posted 04 February 2025 - 09:17 PM
I ripped mine out and filled it with dynax S50.
Posted 04 February 2025 - 09:55 PM
It's a factory thing and likely why I could put my hand through the corners of my roof.
Posted 06 February 2025 - 12:24 PM
if its an earlier car will be to stop rear loom from chaffing on bodywork, later cars loom goes down lhs floor pan
Posted 08 February 2025 - 01:57 AM
The car is supposed to have originally been a 1978, RHD Mini 1000. It was converted to LHD, before we got it. It also is powered by an MG metro engine.
I found the foam in the right hand A post. The wiring for the rear runs through the left hand A post. There was no foam in that post. But, there was also no roof above the A post so maybe the foam went away with the roof?
Repairing that roof section was fun.
