Jdm Automatic Gearbox Documentation
5 replies to this topic
#1 NLinPEN
NLinPEN
  • 48 posts
Posted 04 February 2025 - 11:30 AM
I am searching for documentation on the automatic gearbox as mounted on the Japanese (JDM) Mini's. I do have a workshop manual but it only describes the manual gearbox, not the automatic gearbox. Are there other documents available that do cover this automatic gearbox?
The reason for asking this is that I have the impression that there is a misalignment between the gearbox lever and the gearbox in my car. Especially between Neutral and Reverse is the gearbox doing something different than what the lever indicates. I don't know whether this means that a cable has come loose, or that there is an adjustment screw that I need to adjust. My car is one of the 1990's Japanese Mini, with automatic gearbox, SPi engine, A/C, and an MPi-style fusebox in the passenger cabin.
#2 mab01uk
mab01uk
  • 12,370 posts
Posted 04 February 2025 - 12:02 PM
Also maybe worth asking and searching for any info on the 'Automatic Mini Register' forum linked below:-
Automatic Mini Register:-
https://autominiregi....proboards.com/
Edited by mab01uk, 04 February 2025 - 12:04 PM.
#3 mab01uk
mab01uk
  • 12,370 posts
Posted 04 February 2025 - 12:24 PM
These PDF file manuals linked below are a useful for reference, although there may be some differences to the later JDM AP automatic box.
AP-Mini-Automatic-Transmission-Service-Manual:-
https://www.widman.b...vice-Manual.pdf
AKM4694-Mini-Automatic-supplement:-
https://www.widman.b...-supplement.pdf
Mini-auto-gear-box:-
https://www.widman.b...to-gear-box.pdf
Foulis-automatic-transmission-manual-Mini:-
https://www.widman.b...manual-mini.pdf
Also this 'Mini Classic Automatic' Facebook group maybe of help:-
https://www.facebook...4/?locale=en_GB
#4 NLinPEN
NLinPEN
  • 48 posts
Posted 04 February 2025 - 02:01 PM
Thank you mab01uk, these resources are very helpful!
The document titled Mini-auto-gear-box has a drawing of the gear selector lever as it is in my car (page #20 of the pdf, picture number 44M0016). It also describes how to check and adjust the cable. This is a good first step for me to execute.
#5 Richard1
Richard1
  • 56 posts
Posted 11 February 2025 - 10:35 PM
The selector adjustment is on the transmission end, as you will see in those pdf's, having put a spacer at the D end of the handle. I forget the exact dimensions (they are listed somewhere there), but it is around 2 mm or so.
You may also find that wear has taken place in the pivots of the shift lever. My R is not right on, even though the rest is.
#6 NLinPEN
NLinPEN
  • 48 posts
Posted 12 February 2025 - 02:46 AM
Thank you. Yes, I found the adjustment procedure and was able to adjust accordingly. Now all is fine.
