I had to do some work under the dash board which required the removal of the pedal box ( bugger of a job when your over 70!) . I am now refitting it all after a couple of weeks and I'm struggling to understand how the switch assembly is fixed to operate when the brake pedal is depressed. The switch assembly bolts on to the pedal box frame but can't figure out the orientation for the switch to operate. A photo of an in-service one would help me enormously. Photo of swich attached.
1989 Mini Sky Rear Brake Light Switch Fitting
Edington
, Feb 03 2025 04:51 PM
3 replies to this topic
Posted 03 February 2025 - 04:51 PM
Posted 03 February 2025 - 05:14 PM
Hi,
The switch as I understand it works the following way.
Pedal in rest position the switch plunger is pushed in thus breaking the circuit.
As you press the pedal the plunger is released thus completing the circuit allowing the break lights to come on.
In Stuart's top photo you can see that the switch is above the brake pedal thus allowing the above actions to take place.
Paddy
Posted 03 February 2025 - 05:42 PM
Ah, I think I can now see how it fits. Thanks guys.
