Cooper S Stopping( Braking) Distance
Posted 02 February 2025 - 03:29 PM
What I need to know is what was the official stopping/braking distance from say 60-0 or something similar, I've had a poke around the net but can't find a road test from period. The only thing that popped up was the Google AI thing and that stated 140' and I'm not a massive fan of that for reliable info.
Shooter
Posted 03 February 2025 - 09:54 AM
Thanks for the mention here mate, but sorry, I can't readily lay my hands on that info, I'm sure Martin would have it.
Posted 03 February 2025 - 10:03 AM
how relevant would that 'official' measurement be, anyway?
at what time of year, what weather, what tyres, what road surface, what brake pads, how many people in the car, any luggage? .. etc
were they even doing that sort of test and logging results back then? before the days of euro ncap
Edited by stuart bowes, 03 February 2025 - 10:04 AM.
Posted 03 February 2025 - 10:31 AM
Road tests used to log all sorts of data, but the ones I can find today mainly measured acceleration rather than braking. The few results I found didn't show stopping distance:
Cooper 997 braking 60mph to zero = 5 seconds
1275GT (twin carb) braking 100kph to zero = 4.3 seconds
Some test have G forces:
Cooper 997 braking 60mph to zero = 0.68G
Mk2 Cooper S braking 60mph to zero = 0.88G
Base clubman braking 60mph to zero = 0.68G
Clubman GT braking 60mph to zero = 0.88G
Edited by timmy850, 03 February 2025 - 10:33 AM.
Posted 03 February 2025 - 10:34 AM
Different tyres & friction material would make it irrelevant today, even if it exists - If you want it for practical purposes.
Some sort of comparison ought to be possible from looking at brake line pressure; piston & pad area; the relative diameters of drums/discs & tyres.
I expect quoted stopping distances come from real world tests under controlled conditions. You could potentially conduct your own if you can find their criteria
Posted 03 February 2025 - 10:36 AM
A 1964 Autocar test of the 1275 Cooper S has these figures below for the 'from 30mph' in neutral brake test:-
Pedal Load 25lb, Retardation 0.50g, Equiv. Distance 60ft.
Pedal Load 50lb, Retardation 0.90g, Equiv. Distance 33.5ft.
Test Conditions: Dry concrete and tarmac surfaces.
Extract taken below from an Autocar magazine Road Test in 1963 for the 1071 Cooper S also has some info for braking from 30mph in neutral.
Test Conditions: Wet tarmac and concrete surfaces.
Edited by mab01uk, 03 February 2025 - 10:54 AM.
Posted 03 February 2025 - 10:57 AM
That's how they did it, back in the day, with a pendulum gizmo sat on the car's floor. Still do, if you can find someone who MOTs 3 wheelers. I presume the figures are maximums & there was only a pass score, nothing model specific.
Posted 03 February 2025 - 11:01 AM
This article testing Mini tyres linked below may also be of interest.
Mini Tyre Test (Practical Classics - Dec 2006):-
https://www.theminif...6/#entry3743993
Edited by mab01uk, 03 February 2025 - 11:03 AM.
Posted 03 February 2025 - 05:36 PM
Posted 03 February 2025 - 07:06 PM
Posted 03 February 2025 - 08:16 PM
Thanks for that very helpful, much appreciated.
Shooter
Posted 03 February 2025 - 09:05 PM
Posted 04 February 2025 - 06:33 PM
Those Tapley meters are still used today for testing modern cars if they're certain types of 4wd or have an LSD or if you're testing an old elastic band drive DAF.
MOT on my old 4WD Audi S6 used to use the meter
