Door Card Repair
4 replies to this topic
#1 gaspen
gaspen
  • 937 posts
Posted 31 January 2025 - 10:48 AM
Hello
In my 850 I have  Autumn Leaf  "furniture" in pretty bad shape.  The door cards damaged also, but I do want to keep them. I've made new cards from foamed PVC.
Unfortunately the covers separated from the back foil.
Is it possible to weld or glue a new foil to the cover ? Maybe I should glue the cover to the edge of the card ?
Attached File  20250129_130638.jpg   44.88K   2 downloadsAttached File  20250129_130652.jpg   17.38K   2 downloadsAttached File  20250129_130657.jpg   30.8K   2 downloadsAttached File  20250129_130705.jpg   30.98K   1 downloads
#2 sledgehammer
sledgehammer
  • 3,098 posts
Posted 01 February 2025 - 05:55 PM
I cheated -
Don't know if it will work for you
laminate flooring , screwed over the top
otherwise it just kept coming loose
It was carpet at the bottom , it would not stay stuck
Edited by sledgehammer, 01 February 2025 - 05:58 PM.
#3 Ethel
  • 25,909 posts
Posted 02 February 2025 - 12:27 AM
It looks like you've made a very neat job of that new board.
I've never peeled a door card like that so I wouldn't know how tough the vinyl is. But it looks like you might manage to lay a strip of foam and fix it with broad tape stuck directly to the vinyl on one side & the remaining backing on the other. You'd  then have the vinyl attached along the old joint, so you could lay on another piece of foam & tape in the same fashion. You can get 4 inch rolls of aluminium tape from Screwfix etc, but you might want to experiment with how you can stick it to your new card.
#4 Homersimpson
Homersimpson
  • 829 posts
Posted 08 February 2025 - 11:00 PM
Just to add to this, if you need to recolour them then I've used this with great results: https://www.kolorbon...-leather-vinyl/
I just sent them a sample of the colour so they could match it and then sprayed it on, it even worked well to change door card colour here:
https://forum.retro-...67-auto?page=17
I've done two MK2 jags like this with great results.
#5 gaspen
gaspen
  • 937 posts
Posted 09 February 2025 - 11:51 AM
That would be a 2000 km trip for me :)
