Crackling Nosies
Posted Today, 09:15 AM
Posted Today, 09:18 AM
Posted Today, 10:12 AM
Morning when I put ingnition on there is a crackling sound coming from dizzy I have a lumenition optronic ignition. Checked that out all seems well. Still getting spark but car want start .if I need new dizzy which is most compatible. Cheers
Sage & Onion goes well with pork crackling.
Posted Today, 11:01 AM
Posted Today, 11:09 AM
The first thing I'd try is a hair dryer blowing low heat around it for an hour or so, to eliminate damp.
What is the state of your engine’s tune ?
Posted Today, 12:36 PM
Have you checked the state of the cap, rotor arm and cables it could be a failing component and what you are hearing could be the high voltage arcing across something.
If you check either at night or in low light it would help external arcing but if it in the distributor then close inspection might real some signs.
1 members, 2 guests, 0 anonymous users
weef
