Valve Oil Seal Order Of Installation?
8 replies to this topic
#1 babsbrown
babsbrown
  • 510 posts
Posted 29 January 2025 - 06:18 PM
Good evening guys,
I've traulled the forum and Haynes manual with no definite answer.
I'm putting my valves in the cylinder head and I'm unsure of the order in which things go.
Am I right in thinking it would go
Metal oil seal, spring, top hat, then collets? Ie
2 then 3, the 1?
I also have the larger rubber oil seals. I take it these push on top of the valve guide and fit in the grooves?
Could I use these as well as the metal ones?
Thank you, babs
Edited by babsbrown, 29 January 2025 - 06:23 PM.
#2 nicklouse
  • 18,689 posts
Posted 29 January 2025 - 07:42 PM
What is 2?
I would fit correct stem seal. Then spring-cap compress and collets.
https://www.minispar...d-on-mpi-models
#3 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 29 January 2025 - 08:15 PM
The manual shows the “shroud for valve guide” as being up the other way. They had no stem seals on the valve guides
Edited by timmy850, 29 January 2025 - 08:19 PM.
#4 babsbrown
babsbrown
  • 510 posts
Posted 29 January 2025 - 09:26 PM
Ah excellent thanks gents. I didn't see that in the Haynes, perhaps mines too modern.
In your opinions which is the better setup to go for? I have both the modern seals and the older o ring type rubbers.
#5 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 29 January 2025 - 10:13 PM
Just use the modern ones if they suit your valve guides. Ditch the old metal shrouds
#6 Shooter63
Shooter63
  • 1,067 posts
Posted 30 January 2025 - 07:19 PM
No shrouds, Viton stem seals would be best, if you fit the shrouds they tend to mangle the seals. I've never been able to work out how the O ring idea is supposed to work.
Shooter
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 31 January 2025 - 08:05 PM
The o rings are useless. As suggested above ditch the shrouds and use the latest MPI spec (brown) viton stem seals.
Phil.
#8 babsbrown
babsbrown
  • 510 posts
Posted 31 January 2025 - 11:25 PM
Thanks gents, much appreciate your help as always, it's really reassuring, especially when doing this for the first time.
I got all the springs fitted today with the later style valve seals on the inlet valves.
Cheers,
#9 babsbrown
babsbrown
  • 510 posts
Posted 31 January 2025 - 11:27 PM
Attached File  17383660341662064993553213765617.jpg   37.1K   2 downloads
