Looking for one spacer that sits between caliber halves on Metro 4 pot vented brakes. A complete caliber is Ok also, no matter left or right.
Broms.jpg 53.26K
1 downloads
Posted 29 January 2025 - 03:46 PM
There was no spacer when vented discs became standard on all Metros.
Minispares do a spacer kit for their alloy 4 pots. could be worth a lokk if you run out of other options.
Posted 29 January 2025 - 05:46 PM
I have a spacer in mine, about 10mm thick. They are from MG Metro Turbo. Will try to find the Minispares kit, thanks.
Out of stock!
Edited by TRS666, 29 January 2025 - 05:49 PM.
Posted 29 January 2025 - 09:07 PM
Just spotted these https://www.ebay.co....:Bk9SR5L4gbyWZQ
Good catch, thanks a lot. Now just asking if he could send to Sweden.
Posted 29 January 2025 - 10:52 PM
They look like they could be alloy, but they also look a bit different to the Minispares offering.
Posted 30 January 2025 - 03:44 PM
Found another seller who sends to Sweden:https://order.ebay.c...segname=11401#/
They are alloy and used when you convert Metro with solid discs to vented so should be OK for me.
Thanks for help.
Posted 31 January 2025 - 11:06 AM
If I remember correctly there are two types of Metro vented callipers. One is two halves and the other is three sections with a spacer in the middle.
Posted 31 January 2025 - 12:52 PM
Could be, mine are 3 sections with spacer. Think late Metros had sliding calibers with one huge piston.
Posted 31 January 2025 - 01:05 PM
When the turbo was introduced they used a spacer. Then (1885?) all Metros got vented discs, without spacers. The Rover 100/Metro, with the K Series engine, used sliding calipers.
