Catalytic Converter Problem
Posted 23 January 2025 - 05:48 PM
Posted 23 January 2025 - 06:25 PM
Assuming the exhaust system post cat has no obstructions to flow, it may be an over fueling issue or a cylinder not firing causing the unburnt fuel igniting in the cat.
The cat does run hot but not glowing red under normal running, I can only think it's an overfueling issue based on my experience when carrying out a forced regen of a cat, usually diesels, where excess fuel is injected into the engine to burn off contaminents in the cat, thats when they glow red and smell a bit.
Hope this helps.
Posted 23 January 2025 - 07:26 PM
Posted 23 January 2025 - 08:43 PM
Posted 23 January 2025 - 09:09 PM
I had a similar glowing cat on an early 2000s VW. It turned out to be half the coil pack dyeing and unburnt fuel front two cylinders being dumped into a hot cat.
Posted 23 January 2025 - 10:45 PM
From what's been said, it's likely a plug lead is loose or damaged.
Posted 24 January 2025 - 09:24 AM
You could also check you haven't disturbed the Lambda sensor or it's wiring, when you did the oil change.
If it has happen straight after you doing the oil change, I would think you have knocked a lead or pipe.
