Tool To Remove 2Nd And 3Rd Gear From The Main Shaft
9 replies to this topic
#1 dotmatrix
dotmatrix
  • 439 posts
Posted 20 January 2025 - 09:08 PM
hi.
I was wondering, is there a tool to press in the one and the two small spring loaded pins for when you remove the gears from the main shaft. its easy enough when you put it back together, its the disassembly thats fiddly. was or is there any tools available to press those in?
thanks in advance
Martin
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 20 January 2025 - 09:17 PM
Just some stiff wire - get a scrap of 2.5mm ‘twin and earth’ and strip some of the copper wire out of it.
Alternatively sacrifice a couple of old watchmakers screwdrivers
#3 dotmatrix
dotmatrix
  • 439 posts
Posted 20 January 2025 - 09:19 PM
currently using a couple of screwdrivers. thought there might be some soft of triangle shaped tool or something that could be wedged down the press the pin in while rotating :-)
#4 KTS
KTS
  • 2,421 posts
Posted 21 January 2025 - 08:16 AM
it's been a couple of years since i last had to do it, but i thought there's enough play in the locking collar to push one pin in and rotate the collar enough to hold it in and then do the second pin
#5 coopertaz
coopertaz
  • 791 posts
  • Local Club: a-series-magpies
Posted 21 January 2025 - 01:10 PM
you should be able to do as above but find seal pics with small pointed ends are useful here
#6 DeadSquare
DeadSquare
  • 3,089 posts
Posted 21 January 2025 - 03:08 PM
That is how it leaves you feeling, that it can be done, in the Workshop Manual.
The Manual tells you, when dismantling, to do it under a cloth.  It doesn't mention reassembling with the parts and your hands, inside a clear polythene bag.
#7 Spider
  • 14,841 posts
Posted 21 January 2025 - 05:22 PM
I have a right angle 'Pick' or Pointed tool I have for depressing the Pins in. I've tried lots of things over the years, all a fiddle, none perfect.
#8 dotmatrix
dotmatrix
  • 439 posts
Posted 21 January 2025 - 08:47 PM
there is. this is how I do it.
just thought that there must be a tool that makes disassembly easier. they did so many special tools, most of which I don't need
#9 dotmatrix
dotmatrix
  • 439 posts
Posted 21 January 2025 - 08:48 PM
I am able to do it like above.
I just hoped there was a easier way. I always over rotate the collar and then i'm back to where I started.
#10 dotmatrix
dotmatrix
  • 439 posts
Posted 21 January 2025 - 08:49 PM
reassembly is easier than disassembly. there is two holes in the gear which you can use to press the pins and springs in while you push the collar down. much easier than taking it apart
