Rubbing Noise - Offside Front
6 replies to this topic
#1 gruck62
gruck62
  • 13 posts
Posted 19 January 2025 - 08:32 AM
1983 Mini Mayfair
Hi.  as the weather has been good for a few days I decided to give the old girl a run out.
There is a noise from what appears to be the offside front wheel.
It sound like something is rubbing and is speed dependent as when I slow right down, so does the noise.
When I coast down hill with the engine off ( private land of course ! ) it is still there.
No difference if I turn left or right.
best described as a whoosh, whoosh, whoosh.
Any suggestions would be welcomed as I want it sorted before the spring.
TIA
#2 absx2
absx2
  • 902 posts
Posted 19 January 2025 - 09:20 AM
It could be the disc shroud rubbing if you have one as you may have picked up a stone.
Your brake pads could be getting thin and touching metal.
It could be the wheel bearing but that is normally a squeaking noise.
I would get the wheel in the air and give it a spin, hopefully there`s something easy to fix.
#3 MiniMadRacer
MiniMadRacer
  • 886 posts
Posted 19 January 2025 - 09:21 AM
Could be the pads rubbing on the discs, esp if any rust has built up, does the noise change in anyway when you brake?
I would jack the car up on the offside and spin the wheel by hand, can you hear any rubbing then. If so that would most likely rule out the wheel / tyre touching the bodywork at least
#4 MiniMadRacer
MiniMadRacer
  • 886 posts
Posted 19 January 2025 - 09:29 AM
Absx2, you beat me too it :D
#5 andyapanel
andyapanel
  • 620 posts
Posted 20 January 2025 - 07:38 AM
I would expect another dust shield to have failed if it was on one of my minis.
#6 coopertaz
coopertaz
  • 781 posts
  • Local Club: a-series-magpies
Posted 21 January 2025 - 01:20 PM
1983, is it not still on front drum brakes? could be crud on shoes or drum from being stood or rust around backplate flange catching on drum.
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,337 posts
  • Local Club: Amoc
Posted 21 January 2025 - 04:37 PM
If not the back plate
Could be
C.v.boot grease retaining clip possibly.
Some people use the dreaded tie wrap which is not the correct part... usually hits the fattest part of the tie wrap.
OR.
Could also just be a slack wheel nuts issue
Edited by bpirie1000, 21 January 2025 - 04:38 PM.
