Low Oil Pressure
31 replies to this topic
#31 Cooperman
  • 23,201 posts
Posted 23 January 2025 - 05:52 PM
Don't use an oil additive, such as 'Liqui-Moly' or 'Wynns' in a Mini. It shares the oil with the gearbox and the syncros don't like additives. What the gearboxes do like is zinc at a minimum of 1200 ppm.
#32 miniGTS
miniGTS
  • 219 posts
Posted 23 January 2025 - 06:40 PM
Thank you, yes that's the same as most of the info I found on the issue. The reason I decided to use Ravenol is some locals did the research and found the Ravenol to have the highest zinc of the oils fairly easily available.
