I've sorted the pipe for the Smiths oil pressure gauge. It shows a drop in oil pressure when hot to below 15psi. That's with idle at 1100 to 1200rpm. So a sign that things are not well inside the engine. Pressure goes up with the revs, around 60psi over 5000rpm and makes a brief whining or screeching sound when I lift my foot off the accelerator and the revs drop. This noise is only heard when hot.
There's no obvious knocking yet so thinking the bearings may not have reached the point where it caused other damage. Though I'd only know this once I've opened it up.
So, before I spend a fortune on having my other engine rebuilt sooner than I planned, I'm thinking of opening this one up and checking what's going on inside first. This engine is a bit of a screamer so want to enjoy it a bit longer before I kill it completely.
I know the bores are good because I checked them when I had the head off not so long ago... Probably did less than 100km since... The engine hasn't done more than a few hundred km since rebuilt 15 to 20 years ago... Clearly mistakes were made that I hope to not make again...this time I'll use new bearings and thrust washers after having the crank and block checked at the engineers and they tell me the correct sizes.
So that I can work out a rough cost estimate for parts needed, apart from bearings and oil pump, what else can cause low oil pressure?
I have a complete engine and gearbox gasket set. I'll just need to get a new head gasket.
Edited by miniGTS, 22 January 2025 - 07:35 PM.
