Downton Sport 40 Refresh. Mill Road Garage Iow
20 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2025 - 01:04 PM
It seems like a long time since I have posted a rebuild thread on here. Well in fact, it has been a long time but plenty has been happening at Mill Road Garage and today I have a free day so have decided I'd share the refresh of a Downton sport 40 I have been doing for a customer over the past few months.
This car was purchased brand new by my customer in Geneva in I believe 2000 and started life as a Sportspack Cooper.
It was sent early on in its life to Downton for a limited numbers conversion which they called the Downton Sport 40 however the limited run of 5 cars was already complete so a one off conversion was done by them to this car.
It has that early Mini look inside with the centrally mounted oval speedo and a pair of low slung bucket seats, A look that I am very much in favour of.
A half cage and twin tank conversion was also fitted.
Further engine modifications were performed elsewhere after the conversion but the name of whom fails me at the moment. Ill check with the customer and edit later
It has a 5 speed gearbox also
It then spent some time with Lumenition as a test and development mule for a new engine management system they were planning to produce. I believe that this didn't reach production so this may be the only car that its fitted to.
During this time, the car was UK registered so that the modifications could be legal as ive been told that the European MOT in Brussels where this car lives does not allow for modifications.
In more recent years, the owner had decided he no longer liked the Downton styling so started to go his own route by removing the Group5 arches, 12" Minilight wheels in favour of 10" rose petals and no arches and fitting a pair of clubman rear bumpers.
This however left the issue of the front arches having been factory cut for the sportspack arches and of course the mounting holes as well as uneven paint matching following the earlier conversion work.
Here is the car as it arrived to me
Overall, it is a very low mileage, pretty much rust free example but is in need of a refresh as its looking tired.
The brief was a simple one.... sort out the arches so that it can run chrome de-luxe side trims, fix the paintwork, and convert it to right hand drive.
Edited by Ben_O, 16 January 2025 - 01:07 PM.
#2 cooperd70
cooperd70
  • 726 posts
Posted 16 January 2025 - 01:28 PM
Ben
Great write up...I remember you posting about this car over the past few months as the ignition system stands out in my memory.
It sounds like a very special car with all the trick bits of work it's had done to it over the years. The owner will need to write all of this up and pop it in it's history file {if he hasn't done so already}.
Looking forward to any updates on this one {as and when you have time of course} 😊
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2025 - 01:30 PM
Before I could start the repairs, I needed to strip the car out.
The underside is very good except for jacking damage on the floor pans but the factory sealer is messy and we need to preserve this car so the uneven and for the most part, missing factory coatings which are responsible for these usually dissolving will not do going forward so it was decided a bare shell strip would be the best way.
So engine out
Interior out
During the stripdown, I found the interior wiring to be quite a mess.
Usually this wiring on the late cars is hidden behind a full dashboard and includes relays and control modules and these do not lend very well to retrofitting an earlier dash layout without moving it all.
This is something that unfortunately hasn't been done well on this car
I have a plan for this later on though
Once the car was stripped down, I cut off the front end
It is rust free so this was a shame to have to do but was essential to reinstate the full arches that have been cut for the sportspack conversion
I cleaned back the minimal surface rust and factory coatings from the inner wings
And removed the factory anti drum
You can see that I have straightened out the front floor pans too
Here was the jacking damage prior to that
Next, I started to mock up the wiring reroute using a centre speedo conversion from nippycars so that it could house the rev counter in a neater way than before
The moves the bulk away from above to below which should make for a better finish of the trim
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2025 - 01:49 PM
A strange shaped hole had been cut during its previous conversion to allow for the speedo cable
As I have a bare shell and can clearly see where the cable needs to sit, I can take this chance to tidy this up
And ill relocate one of the heater hoses so it doesn't interfere with the dash trimming later
It'll now come up through the pedal box blanking plate
Time for the new front end
I also fixed the door fit and a few dents to those
And welded up the surplus arch mounting holes in the quarter panels
And then stripped the areas that had been previously repainted back to bare metal as well as the new front end
That's the basics done
The car was originally fitted with a modified late boot lid using an early hinged number plate and number plate lamp
I got a new early bootlid and modified that to incorporate a new number plate light that has an inbuilt fog and reverse lamp. The owner did not want a hinged number plate anymore so that was discarded at this point too
Then into the booth for epoxy primer
Next job was to prep the panels for primer
The bonnet had an awful lot of paint on it so i stripped that back
The shell then had a few small imerfections ironed out before being sprayed in high build primer
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2025 - 01:59 PM
Next was the horrible job of stripping the underside
New floor bungs were put in
And then I primed, sealed and recoated the underside
So nice to not have to do any welding on the floors for once
Next job, paint the bare bits inside the shell.
Most of it was in fine fettle and it did not fit the brief to paint it all so i just did the floor pans, one companion bin and the front builkhead
And then the engine bay had the same treatment
And that just leaves the exterior paintwork to do
#6 colinf1
colinf1
  • 1,013 posts
Posted 16 January 2025 - 02:07 PM
Great to see a new thread from you Ben_O!
Looks like your as indepth as ever with your repairs!
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,341 posts
  • Local Club: Amoc
Posted 16 January 2025 - 02:09 PM
Lovely work for a lovely car. Well done the owner getting it at this stage and doing the work required.
So many look and see from the outside that it looks o.k. and put up with that.. this owner is doing the right thing... in my humble opinion.........
Nice to see a retro edition - very jealous of the seats.
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2025 - 03:22 PM
The next stage was to mask the shell ready for its final top coat
And then time for paint
I adore this colour, it looks both retro and modern at the same time to my eyes
Next up, onto stands for the rebuild
First job is always to run the brake and fuel lines so they were cleaned, checked and fitted
Mk2 rear lights
Then subframes.
They are both in great condition, however are dirty so I removed the radius arms to make cleaning easier and also so I can fit new doughnuts and go through everything
All clean
I then cleaned the front frame and fitted new doughnuts, adjustable lower arms and checked through everything
And then fitted the frames to the car
I also obviously fitted a new RHD steering rack.
As part of the RHD conversion, I needed to replace the pedal box as these are different entirely.
I was unable to find all of the parts new or second hand so I ended up purchasing a NOS MPI pedal box, a used complete late carb pedal box and then made up what I needed from the parts after they were cleaned and painted
It also needed a replacement throttle pedal as the LHD one is different
The brake light switch bracket is different too so I made a new one using one from another Mini as a pattern
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 January 2025 - 03:39 PM
Now onto the wiring and interior fit out
Its so nice to have those correct liner cards in and all the wiring hidden away
And some nice new anti drum
Then the engine goes back in
more on the back end
RHD headlamps fitted
Doors on and wheels on
Then back in the booth for a roof repaint
Not strictly needed but looks better for the freshen up as it had some marks
Bonnet on
Rear seats, trim, new headlining and roll cage in
And that brings us up to date
Not a huge amount left to do really
Thanks for looking
Ben
Edited by Ben_O, 16 January 2025 - 07:36 PM.
#10 MatthewsDad
MatthewsDad
  • 808 posts
Posted 16 January 2025 - 04:17 PM
That's amazing work! Really impressed.
#11 petey81
petey81
  • 1,314 posts
Posted 16 January 2025 - 04:29 PM
Amazing work!!!!
#12 Chris1275gt
Chris1275gt
  • 937 posts
Posted 16 January 2025 - 04:30 PM
Great to see you back again Ben. I can see that absolute top quality work is still your foundation. Really appreciate viewing these masterpieces. Keep it coming!
#13 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 16 January 2025 - 04:42 PM
Great work Ben, I remember seeing this on one of my visits, beautiful colour scheme.
#14 cooperd70
cooperd70
  • 726 posts
Posted 16 January 2025 - 05:21 PM
Fantastic! I miss these through posts with pics. Amazing work as always 😊
#15 Blumeanie
Blumeanie
  • 153 posts
Posted 16 January 2025 - 05:23 PM
Amazing work!
Thank you for taking the time to post all these beautiful pictures! (I learn a lot from seeing minis torn apart as I do not have any minis anywhere near me!)
