Electronic Distributor Help
Posted 12 January 2025 - 10:27 PM
I've just installed a Minispares electronic Distributor
https://www.minispar...-276-cam-profil
And it appears that the module has gone puff immediately.
I'm trying to diagnose.
What on earth could have caused this?
I have the gold coil (https://www.minispar...erformance-type) which has over 12V to it with the ignition on.
I'm at a loss.
Posted 12 January 2025 - 10:36 PM
You’ve bought a low power 3.0ohm coil which means you’ve cut the power of the spark significantly
You also need to make sure the distributor module is fed 12v and not a ballast (pink) wire which will cut power to the electronics
Posted 12 January 2025 - 10:41 PM
Posted 12 January 2025 - 11:25 PM
If it is functioning it might be making such a weak spark it won’t start
Whether this will cause the module to fail I’m not sure. If they are the powerspark modules then they are replaceable
Posted 13 January 2025 - 03:23 AM
That module will work with standard coils however it's not a good idea. It will run perfectly fine however the life of the coil will be significantly reduced. How have you got it wired up?
Posted 13 January 2025 - 03:30 AM
There was a wisp of smoke that wafted through the centre dash hole/heater area when I tried to start it this morning, then absolutely nothing. No spark whatsoever.
Posted 13 January 2025 - 03:36 AM
You might need to get a multimeter out and trace all the wires and check what voltage they have and if there are any burnt wires or blown fuses
Posted 13 January 2025 - 03:52 AM
I'll try and do a bit more research.
Posted 13 January 2025 - 04:23 AM
White wire goes to coil positive side.
White/black goes from coil negative to distributor
Can you check to see if the white wire gets 12v when you have the key on?
Generally speaking on a negative earth mini the only wire on the negative post of a coil is the distributor and the tacho signal
https://www.classicm...hive/electrical
https://classicminid...ER SWITCHES.PDF
Edited by timmy850, 13 January 2025 - 04:26 AM.
Posted 13 January 2025 - 11:11 AM
I wired it up red to +ve coil, black to the black and white wire that disappears into the look and (I believe) attaches to -ve coil.
That sounds like your problem. You've wired it incorrectly. There's still a chance you haven't cooked the module but the fact you noticed smoke is an issue. Did you happen to leave the engine earth strap disconnected too? Leaving the strap disconnected typically melts the heater/choke cables and therefore releasing smoke.
As Timmy850 has said:
- The red wire should go to the coil positive.
- The black wire should go to the coil negative.
- That white wire most likely goes to the coil positive to supply 12v unless it has a black stripe.
Also, I hope that distributor actually suits your engine as it has a very specific advance curve. I haven't tested that one but here's the curve of the C-27H7699. It doesn't start advancing until 2000 engine rpm.
image_2025-01-13_211636684.png 96.63K 3 downloads
Edited by 68+86auto, 13 January 2025 - 11:18 AM.
