Effing Nora! Pass The Defribulator!
17 replies to this topic
#1 Gaz66
Gaz66
  • 801 posts
Posted 11 January 2025 - 09:36 PM
Just been to add some hardy spicer nuts and bolts to my ever expanding minispares basket and nearly had another coronary experience.
£3.65 per bolt and £1.01 per nut 😳😳😳
The minispares apology for the price of the nuts should also be on the bolts page too, and in bold 😁
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,008 posts
  • Name: Neil
Posted 11 January 2025 - 10:14 PM
Try this lot.
https://www.namrick.co.uk/
#3 nicklouse
  • 18,377 posts
Posted 11 January 2025 - 10:27 PM
Yes the Hardy spicer “bolts” and Philidas “nuts” are expensive. But still cheaper than aircraft grade ones.
#4 nicklouse
  • 18,377 posts
Posted 11 January 2025 - 10:31 PM
Also cheaper than https://www.med-engi...upling-bolt-kit
A 5/16 K nut is about 1.50.
#5 Gaz66
Gaz66
  • 801 posts
Posted 11 January 2025 - 10:44 PM
Is there a reason why Philidas nuts are used over nylocs?
Not that the Philidas nuts are the issue, it's the bolts. 😁
#6 imack
imack
  • 2,016 posts
Posted 12 January 2025 - 07:49 AM
The nuts need to be very shallow, a standard nylon would be too tall, a 1/2 nylon may fit. But there's heat to consider, the heat from the exhaust manifold and heat transfer from the engine oil would probably melt the nyloc. The exhaust heat used to melt my old QL5000 joints.
QL5000 and standard rubber couplings used to use Philip's nuts too, probably due to the heat issue.
#7 weef
weef
  • 459 posts
Posted 12 January 2025 - 01:20 PM
When we used to be stuck for a locking nut, using a blunt punch on the top thread of an ordinary nut to half pitch it in a couple of places did the trick. They never came loose and did not damage the bolt thread and I suppose a drop of locking adhesive on the thread would not be out of place.
#8 Gaz66
Gaz66
  • 801 posts
Posted 12 January 2025 - 01:51 PM
I think the Philidas nuts work in a similar way looking at them.
#9 weef
weef
  • 459 posts
Posted 12 January 2025 - 04:05 PM
Look on E Bay  " BSA Norton stiff locking nut", might be what you are looking for.
#10 Gaz66
Gaz66
  • 801 posts
Posted 12 January 2025 - 05:06 PM
They look like the fellas 👍
Think I'll be buying the "official" bolts though due to head shape and material spec which is a bit of a stinger 😬
Edited by Gaz66, 12 January 2025 - 05:08 PM.
#11 Designer
Designer
  • 532 posts
  • Local Club: 8 Iron
Posted 13 January 2025 - 08:33 AM
Hi,
What price safety?
If the joint fails not only is it a danger to you but other road users as well if it means you lose control of the car.
Paddy
#12 coopertaz
coopertaz
  • 744 posts
  • Local Club: a-series-magpies
Posted 14 January 2025 - 01:22 PM
find a local bolt and nut supplier near you and take old one in, they will normally have items in stock.
#13 DeadSquare
DeadSquare
  • 3,028 posts
Posted 14 January 2025 - 02:17 PM
At school, I remember the poetry teacher telling us about an Islamic Bard, who used to make steam engines.
He had trouble with nuts coming loose, so he had them put on an anvil and hit with a hammer to make them oval.
Of course, it wouldn't be allowed in England, but he was a foreigner, from the 'Kingdom of Brunei',
Or was it Brunel ?
#14 Gaz66
Gaz66
  • 801 posts
Posted 14 January 2025 - 03:22 PM
I doubt any bolt supplier will have these in stock due to the shape.
https://www.minispar...4x-hardy-spicer
I can see me just pulling me pants down and taking it. 😳
#15 DeadSquare
DeadSquare
  • 3,028 posts
Posted 14 January 2025 - 04:07 PM
If you have a vice and a file, you could file a flat on a hexagonal bolt.
