Mini Cooper Project - Finally Starts
roundnose
11 replies to this topic
#1 piphatch
piphatch
    Just On Tickover
  • 7 posts
Posted 08 January 2025 - 11:50 AM
It's finally happening, work on the Mini instead of the house!!
I've been a Mini owner on and off since my first car, unfortunately a much longer period of time (and more minis) off the road than on it. 3 house referbs later and I finally have the nob to start on the Mini.
This is my 2nd crack (and 3rd shell) at putting one back on the road. This is by far the best one I've had and it's a Cooper (1st one of them too!). Got a lot to do but I have finally made a start after owning it for 4, maybe 5 years.
I'm no mechanic but I'll have a go at most things, plus I'm too tight to pay someone if I think I can do it  :wacko:. Anyway got the engine out last night, made an engine hoist with a cheap chain block and some lifting straps, worked a treat.
Had a couple of issues, the engine mount bolt is fused in place, I even tried pushing it out from underneath with a jack and it wouldn't budge. Also the tope arm steady on the gear linkage bolt won't come out. I got the nut off easy enough but the bolt itself wouldn't come out so I took it out with it attached. Could have done with some more clearance under the car but it came out with a little bit of a fight.
I have a roll over jig in a lock up so I think I get it up on that at some point. The drivers side floor needs replacing where someone did a lovely job patching it up.
Next up...
finish stripping the shell and get it blasted (maybe!)
repair any bad areas
replace over sills with correct ones
floor repair
replace missing inner wings
rear sub-frame build, engine rebuild and front hubs on the list too.
Off skiing this weekend though so nothing happening anytime soon...
#2 Designer
Designer
  • 578 posts
  • Local Club: LSMOC
Posted 08 January 2025 - 07:33 PM
Hi piphatch,
Welcome to the forum.
You will find plenty of expert advice on here and also useful tips.
The first being to make sure you register your TMF+ membership with Minispares in order to get the 71/2% discount on your orders.
Paddy
#3 bpirie1000
bpirie1000
  • Area Managers
  • 2,340 posts
  • Local Club: Amoc
Posted 08 January 2025 - 08:11 PM
Label everything and if in doubt.. take photographs of everything.....
Measure twice, cut once...
Get budget and double it..
Think that is the best advice....
#4 Blumeanie
Blumeanie
  • 152 posts
Posted 08 January 2025 - 08:44 PM
Congratulations - Best of luck!
It is a lovely mini!
- I have a soft spot for those wheels. They are a great fit for a stylish mini.
#5 piphatch
piphatch
    Just On Tickover
  • 7 posts
Posted 09 January 2025 - 03:02 PM
Hi piphatch,
Paddy
Thanks Paddy, with my first unsuccessful rebuild I registered my TMF+ membership with them, unfortunately the mini didn't make it but the parts are safely stored away.
#6 Designer
Designer
  • 578 posts
  • Local Club: LSMOC
Posted 10 January 2025 - 07:33 AM
:thumbsup:
#7 Steve220
Steve220
  • 5,041 posts
  • Local Club: BMC
Posted 10 January 2025 - 11:07 AM
That IS the best advice 🤣 unless you're turboing the car, then triple your budget!
#8 theclassicminishop
theclassicminishop
  • 22 posts
  • Local Club: MOCSA
Posted 12 January 2025 - 05:57 AM
Hi Piphatch
Seems to be an excellent project there.
Good luck.
#9 piphatch
piphatch
    Just On Tickover
  • 7 posts
Posted 31 January 2025 - 02:42 PM
She's back from the blasters and I'm pleasantly surprised  :highfive: . A few new holes and and a couple of areas with pin holes on them but really she's pretty solid.
Not sure why all the photos are upside down or on their side!! They are fine when I open them on my laptop.
Attached File  IMG_5404.jpeg   91.82K   1 downloads
Attached File  IMG_5411.jpeg   74.92K   1 downloads
Attached File  IMG_5412.jpeg   75.99K   2 downloads
Attached File  IMG_5413.jpeg   89.4K   3 downloads
#10 piphatch
piphatch
    Just On Tickover
  • 7 posts
Posted 24 February 2025 - 08:27 AM
Took off the drivers over-sill and found the original still in place along with some rust. That's all come out now. The door step is incredibility clean, there's not a spec of rust and I only removed the amount of floor I did to get rid of a bodged repair. It seems that is the theme for the repairs on this car...
Attached File  IMG_5481.jpg   74.86K   1 downloads
Can someone confirm to me that the flitch panel should only be a single skin and that the cowboys that did this repair have just slapped it on top of the old one please?
Attached File  IMG_5484.jpg   52K   3 downloads
 Attached File  IMG_5485.jpg   43.38K   3 downloads
I've got a new panel so I'm thinking cut it all out and start fresh. Thanks
#11 Steve220
Steve220
  • 5,041 posts
  • Local Club: BMC
Posted 24 February 2025 - 11:18 AM
Yeh, flitch is a single panel. That's been covered over :mmkay: It looks like you've got a solid base for repair!
#12 piphatch
piphatch
    Just On Tickover
  • 7 posts
Posted 13 March 2025 - 02:58 PM
They had indeed covered it with a repair panel, I feel the same has been done on the other side too  :(
I have decided to take it all off along with what remained of the inner wing. Then I'll get a new complete inner wing.
I'm amazed at how good the shell is, there's very little rust really. If the repairs had been done correctly the first time it would have been sound.
