Boot Lid Spot Lamp Fog Light?
13 replies to this topic
#1 iDemonix
iDemonix
  • 962 posts
Posted 06 January 2025 - 11:25 PM
My car is an '88 so it has a reverse light in the cluster and requires a fog light for MOT.
I really love these reverse lamps:
I know they're not in keeping with the period of the car, but that's not the aim of this build, the aim is just whatever I like. I dislike having a fog light hanging from the bumper (like in the pic above), could I simply fit a red bulb in the spot and use it as a fog? Or would it need a white bulb and red lens? I've read the MOT regs and it seems pretty lenient...
#2 DeadSquare
DeadSquare
  • 3,089 posts
Posted 07 January 2025 - 10:25 PM
I came across a "U tube" somewhere, where a guy was putting a 'red diode cluster' in the reflector part.  On a Mini, that would be between the Flasher and the Rear / Brake light.
I didn't watch long enough to find out the car, nor any snags.
#3 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 08 January 2025 - 07:17 AM
So long as the fog light bulb is of a suitable wattage to be brighter than the brake light this should not be a problem. You get very bright LED style bulbs that should fit in but I suppose it depends on the unit bulb fitment..
#4 Bobbins
Bobbins
  • 1,486 posts
Posted 08 January 2025 - 02:32 PM
Are there any specific requirements for the reversing light, e-mark, brightness etc?
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 08 January 2025 - 08:03 PM
typically ranges from 35 watts for basic fog lights to 100 watts or more for higher-performance models. A higher wattage output produces a brighter, more penetrating beam.
#6 Bobbins
Bobbins
  • 1,486 posts
Posted 08 January 2025 - 08:28 PM
Sorry, I’ll rephrase my question … what are the legal requirements for the reversing light?
#7 Ethel
  • 25,919 posts
Posted 08 January 2025 - 08:32 PM
The IVA manual is a handy guide to what is legal.
You can't put a fog light in the standard rear cluster it won't be far enough away from the stop-tail. Reverse lights are limited to 21w, same as brake & fog. That's a "work light" in the piccy  ;-) (as long as its not switched by selecting reverse.)
#8 iDemonix
iDemonix
  • 962 posts
Posted 08 January 2025 - 10:47 PM
Cheers all, looks like I should be fine to use it as a fog light then assuming I get the light colour/brightness right - think that might be my plan!
#9 mini-mad-mark
mini-mad-mark
  • 849 posts
  • Local Club: northants wot no brakes
Posted 08 January 2025 - 11:11 PM
Classic Car LEDS sell a dual LED bulb with red AND white illumination, fit one of those and have both!
#10 weef
weef
  • 489 posts
Posted 08 January 2025 - 11:25 PM
There are quite a few different styles of rear fog lamp available, look at some of the custom build websites, something like Car Builder Solutions have a lot, even some low profile units that could be integrated into the rear bumper.
In the 1960/70's when the Mini was a rally icon, and road legal regulations appeared to be more lax, we all put this style of "reversing lamp" on the bootlid along with the obligitory Cibes mounted up front, a sumpgaurd, a white square on the door and a set of wide rims, wheeling round the country roads, great..............
#11 Gaz66
Gaz66
  • 894 posts
Posted 09 January 2025 - 12:25 AM
I'm sure I've seen some production cars with them built into the cluster 🤔
I could have imagined it though 😁
#12 Ethel
  • 25,919 posts
Posted 09 January 2025 - 11:37 AM
There are, but  they'll have the required 100mm between the fog & the stop/tail.
Might be possible if you used clear ones and moved things around,  but you can't just stick a red light in the reverse.
#13 iDemonix
iDemonix
  • 962 posts
Posted 09 January 2025 - 05:44 PM
Good idea, might think about that!
It's just down to personal preference though, I hate things hanging below the bumper or even integrated - whereas I like a spotlight on the boot lid, and this build is all about whatever I prefer rather than sticking to period features etc.
#14 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 10 January 2025 - 07:23 AM
It is your car. Discuss it with the MOT tester/garage you intend to use...
