Early Cooper Door Chrome Mouldings
4 replies to this topic
#1 TRS666
TRS666
  • 32 posts
Posted 05 January 2025 - 09:32 PM
So i have the chrome door mouldings and the blind rivets for the upper moulding in a MK1. Anyone know where to drill the holes, meaning are they in the middle of the door arch? Difficult to measure where to drill and dont want it to go wrong.
Any help appreciated, don´t find searching!
Attached File  Snip20250105_18.png   115.59K   0 downloads
#2 mab01uk
mab01uk
  • 13,071 posts
Posted 06 January 2025 - 08:19 AM
Details of the rivet positions and tips on how to fit the door trims are posted on the Mk1 Forum in links below, but you will need to register on the forum to access the Technical section.
Mk1 Forum:-
https://mk1-forum.net
Door Trim Rivets:-
https://mk1-forum.ne...pic.php?t=39719
Chrome Door Surround Trim:-
https://mk1-forum.ne...ic.php?p=287001
Edited by mab01uk, 06 January 2025 - 08:21 AM.
#3 TRS666
TRS666
  • 32 posts
Posted 06 January 2025 - 09:08 AM
Mk1 Forum:-
Door Trim Rivets:-
Thanks a lot, vesy useful. Seems they are a little offset as i thought.
#4 Cooperman
  • 23,564 posts
Posted 09 January 2025 - 01:27 PM
My advice is don’t use rivets. I use a good quality RTV adhesive and the ones on my 1964 ‘S’ have been on since 1995 with no problems.
There are no corrosion issues as no water can get behind the chrome bits.
Put the RTV into the channels of the chrome parts and position them on the door. I then wind a continuous piece of string tightly onto the door frame and leave it to cure. Then cut the string and remove it and go around the edges with a plastic knife to remove the excess adhesive.
Drilling holes just encourages rust.
#5 TRS666
TRS666
  • 32 posts
Posted 29 January 2025 - 03:22 PM
Thanks. Sounds as a good way to don it.
