Question About Oil Lines From Engine Block To Rockers.
13 replies to this topic
#1 KobukKobuk
KobukKobuk
  • 70 posts
  • Local Club: Mighty mini
Posted 04 January 2025 - 04:35 PM
Hi all.
One of the questions on the linked topic was why oil was not spraying between the rockers when I opened the rocker cover and started the engine,
so I opened the head again today to check.
First, I sprayed WD40 on the oil line going from the engine head to the rocker post and checked that it came out on the other side.
also, the roller rocker oilline doesn't seem to be a problem too.
Next, I checked the small hole on the side of the engine block that touches the engine head,
and even when I put a stick in and pushed all the way in,there was only a slight stain and no engine oil.
I'm confused as to whether it's normal for the engine oil in this small hole to be halfway up like the holes next to it, or whether it could be clogged.
Are there any additional checks or actions I should take in this case? Or is there something I don't know? I would appreciate your advice.
Edited by KobukKobuk, 04 January 2025 - 04:36 PM.
#2 nicklouse
  • 18,577 posts
Posted 04 January 2025 - 04:55 PM
Has the cam bearing on the front (fan end) of the engine been fitted correctly? That is the oil feed.
#3 imack
imack
  • 2,103 posts
Posted 04 January 2025 - 04:59 PM
Does oil squirt ot of that hole if you crank the engine using the starter motor?
It shouldn't be a constant flow of oil, it should be a pulsed flow.
Assuming you have oil pressure in the main gallery, if you don't get oil here when cranking the engine you've got a potential issue with the cam bearing or camshaft or the oil feed between the front main bearing and cam bearing is obstructed.
#4 r.tec
r.tec
  • 183 posts
  • Local Club: SfG Schoenau
Posted 04 January 2025 - 05:36 PM
A fellow racer frind of mine, Mano from Düsseldorf, once created this leaflet that used to be visible on his now defunct webside. Luckily I saved it to my pc.
I am afraid in German, but you can surely draw some information out of it:
Attached File  Mano Oelkreislauf 01.png   169.83K   23 downloads
#5 KobukKobuk
KobukKobuk
  • 70 posts
Posted 05 January 2025 - 12:16 AM
I've never replaced it before so I'm not sure if the holes in the bearing and block match up.
i can't take the engine out myself so I'm thinking of taking it to a mechanic if that's all I can do.
Thanks your advice.
#6 KobukKobuk
KobukKobuk
  • 70 posts
Posted 05 January 2025 - 12:25 AM
Are you saying to try cranking the engine without the head?
Please excuse my ignorance about maintenance :(
#7 KobukKobuk
KobukKobuk
  • 70 posts
Posted 05 January 2025 - 12:29 AM
Thanks to Google, I now understand German ;)
thank you
#8 imack
imack
  • 2,103 posts
Posted 05 January 2025 - 07:36 AM
Yes.
Obviously place lots of old rag around to catch any oil spillage.
#9 KobukKobuk
KobukKobuk
  • 70 posts
Posted 05 January 2025 - 07:53 AM
Yes.
Thanks for the advice, imac.
I'll try cranking it without the engine head tomorrow.
#10 KobukKobuk
KobukKobuk
  • 70 posts
Posted 06 January 2025 - 04:24 AM
Yes.
I tried turning the crank about 3 times, but unfortunately no oil splattered. :'<
#11 KobukKobuk
KobukKobuk
  • 70 posts
Posted 06 January 2025 - 04:25 AM
Edited by KobukKobuk, 06 January 2025 - 05:12 AM.
#12 imack
imack
  • 2,103 posts
Posted 06 January 2025 - 05:01 PM
You'll probably need to crank it for longer than that to get oil from that drilling even if there's nothing wrong.
Crank it until the oil pressure light goes out, or the gauge(if you have one) starts to show pressure.
You need to build pressure in the main oil gallery and feed the main and big end bearings before you see oil feed to the rockers.
Edited by imack, 06 January 2025 - 05:04 PM.
#13 brivinci
brivinci
  • 1,173 posts
Posted 07 January 2025 - 01:53 AM
Yes! What he said!! The oil drains back out of a lot of the engine once switched off. Usually takes a bit to get the pressure back up. If your motor was to ever sit for a long time, its always best to pre-oil whatever you can, remove plugs, and crank it over till the light goes out of gauge starts to read before things start spinning really fast and create damaging heat.
#14 KobukKobuk
KobukKobuk
  • 70 posts
Posted 07 January 2025 - 11:33 AM
Thanks for both your advice.
I'll try again after I finish my other maintenance.
