Advice On Engine Noise Please. (Video Link Attached)
14 replies to this topic
#1 KobukKobuk
KobukKobuk
  • 85 posts
  • Local Club: Mighty mini
Posted 01 January 2025 - 01:33 AM
Hi everyone.
I would like to hear your opinion on the noise in the video.
I have done engine head cleaning and gasket replacement for a few days and adjusted the valve clearance of the roller rocker to 0.015in.
I finally started my car and the ticking/tapping noise is much louder than before.
One thing I'm worried about is that when I rolled it on the table, the number 6 push rod was slightly bent.
Is the valve clearance incorrect or is there another issue you suspect? Should I replace all the pushrods?
What are the problems you can think of? Please advise.
https://youtu.be/OxuDOe2xz1o
#2 imack
imack
  • 2,382 posts
Posted 01 January 2025 - 07:54 AM
Have you got any oil feed to the rocker shaft? It looks very dry. Oil is normally being flicked every where when the engines running with the rocker cover off.
#3 KobukKobuk
KobukKobuk
  • 85 posts
Posted 01 January 2025 - 09:16 AM
Thanks for the advice.
There is no separate oil feed device to the rocker shaft.
I thought it was okay because I filled it up to the mark on the oil dipstick when I changed the engine oil yesterday.
I'll fill it with a little more engine oil tomorrow and try to start it.
Edited by KobukKobuk, 01 January 2025 - 09:17 AM.
#4 imack
imack
  • 2,382 posts
Posted 01 January 2025 - 09:28 AM
You should have oil feed to the rocker shaft via a drilling in the cylinder head. The feed comes via the head into the 1st rocker post from the right hand side of the engine as you look at it. You either have the wrong rocker post fitted to the right hand position on the rocker shaft or maybe the head gasket on back to front which will be blocking the oil feed between the block and the head.
Edited by imack, 01 January 2025 - 09:41 AM.
#5 mab01uk
mab01uk
  • 13,092 posts
Posted 01 January 2025 - 09:30 AM
Oil is fed into the rocker shaft up from the cylinder head through a small drilling in the head and then up one of the rocker shaft pillars. Check the small oil way is not blocked or the rocker shaft will run dry and wear rapidly.
Do not top up the oil if it is already filled up to the maximum mark on the dipstick as that will make no difference to the rockers and over-filling will create other problems.
Oil route in an A-Series engine:-
https://www.theminif...eries/?p=273105
Edited by mab01uk, 01 January 2025 - 09:37 AM.
#6 Lplus
Lplus
  • 1,004 posts
Posted 01 January 2025 - 09:36 AM
A bent pushrod can touch the side of the hole in the head as it moves up and down, so yes the pushrod should be changed.
Edited by Lplus, 01 January 2025 - 09:36 AM.
#7 KobukKobuk
KobukKobuk
  • 85 posts
Posted 01 January 2025 - 10:23 AM
Thank you for attaching the pictures so that it is easy to understand.
Oh, I thought there was a separate rocker shaft oil supply device.
I didn't know oil was circulated there.
The gasket and rocker seem to have been worked on correctly. The engine head was also cleaned, so the holes are not clogged.
If oil is circulating properly through the rocker shaft, where can I check to see if it is?
#8 KobukKobuk
KobukKobuk
  • 85 posts
Posted 01 January 2025 - 10:28 AM
Thank you. I'm trying to order from Minispares.
Would this be good for the 1999 Japanese SPI 1275?
https://www.minispar...275-aftermarket
Edited by KobukKobuk, 01 January 2025 - 10:29 AM.
#9 KobukKobuk
KobukKobuk
  • 85 posts
Posted 01 January 2025 - 10:33 AM
Edited by KobukKobuk, 01 January 2025 - 10:35 AM.
#10 KobukKobuk
KobukKobuk
  • 85 posts
Posted 01 January 2025 - 10:37 AM
오일은 실린더 헤드에서 헤드의 작은 드릴링을 통해 로커 샤프트로 공급되고, 그다음 로커 샤프트 기둥 중 하나를 통해 공급됩니다. 작은 오일 통로가 막히지 않았는지 확인하십시오. 그렇지 않으면 로커 샤프트가 마르고 빠르게 마모됩니다.
오일이 이미 오일 게이지의 최대 표시까지 채워져 있는 경우 오일을 추가로 채우지 마십시오. 최대 표시까지 채워도 로커에 아무런 변화가 없으며 과도하게 채우면 다른 문제가 발생할 수 있습니다.
A-시리즈 엔진의 오일 경로:-
The oil hole doesn't seem to be clogged.
And I won't add any more engine oil and will check a few more things.
Thanks for the link information too.
#11 Lplus
Lplus
  • 1,004 posts
Posted 01 January 2025 - 11:38 AM
If the engine has a standard cam and valve springs and the rockers aren't super high lift then it should be acceptable.
#12 imack
imack
  • 2,382 posts
Posted 01 January 2025 - 11:58 AM
Oil should be getting fed directly to the rocker bush via the rocker shaft anf post, so oil should be squirting out from between the rocker and the post and the rocker and the spacer tube.
I don't know whether minisport rockers also have direct oil feed to the roller tip and pushrod ball adjuster as the MED ones have.
Oil should be getting sprayed all over the engine if you run it without the rocker cover on.
Edited by imack, 01 January 2025 - 12:00 PM.
#13 imack
imack
  • 2,382 posts
Posted 01 January 2025 - 12:11 PM
Here you can see the oil passage drillings on the MED rocker between the bearing surface and the roller tip and the ball adjuster.
I don't know whether minisport rockers have this feature.
#14 KobukKobuk
KobukKobuk
  • 85 posts
Posted 01 January 2025 - 12:28 PM
Thanks imack. Your advice helped me a lot.
I've been using it for 2 years so I don't think it'll be a problem but I'll check this out.
#15 KobukKobuk
KobukKobuk
  • 85 posts
Posted 04 January 2025 - 04:41 PM
I opened the head today to check it out and another question arose.
If you don't mind, could you please advise me on a new inquiry regarding rocker oil injection?
https://www.theminif...ock-to-rockers/
