Broken Thread On Rear Subframe
suspension
7 replies to this topic
#1 adman020
adman020
  • 21 posts
Posted 29 December 2024 - 05:44 PM
I have removed the rear subframe - i have snapped the thread off one corner...  what are my options?
I am good with a welder.. Do i cut the box section out and weld a new full bolt or drill the broken thread out?
this has probably been asked so many times but i'm new to the mini scene.
#2 Tupers
Tupers
  • 4,142 posts
Posted 29 December 2024 - 07:12 PM
If you find a rotten frame with a good pin they’re easy enough to cut out and replace. I think the last one I did took an hour.
There’s normally just a few stitch welds around the flange that the bush backs onto and another couple between the skid and the rear crossmember.
I have seen people drill and tap the remaining shank to use a bolt but you’ve got drop down a thread size to have any meat around it and I don’t really like that.
#3 DeadSquare
DeadSquare
  • 3,088 posts
Posted 30 December 2024 - 10:09 AM
It is good that you are good with a welder.  Do you have, and are you good with an anglegrinder ?
Faced with your problem, I have:-
1)  Bevelled the head of a Hex set-screw.
2)  Cut the depth of the hex head off the pin and bevelled the pin.
3)  Welded the set-screw to the pin.
4)   Rounded off the hex corners of the set-screw, flush with the pin.
#4 alpder
alpder
  • 383 posts
  • Local Club: MCR
Posted 30 December 2024 - 11:50 AM
I'm not particularly good with a welder, so butt-welding a thread onto the end of the pin would give me a dubiously reliable outcome.
So my approach would have to be instead something that made the welding job easy.
With my level of skill-less-ness I'd take one of two approaches:
(1) Replace the pin completely. Or...
(2) I'd drill into the end of the pin the full dia of the thread, saw off an appropriate length of a shanked bolt, drill thru the side of the pin, press in the new bolt and puddle-weld into the side-hole(s) to fasten it.
Edited by alpder, 30 December 2024 - 11:59 AM.
#5 stuart bowes
stuart bowes
  • 2,089 posts
Posted 30 December 2024 - 01:48 PM
I was thinking the same except thread the hole and turn the stud in, then plug it from the sides
I haven't ever done that myself though so purely theory not experience
#6 bpirie1000
bpirie1000
  • Area Managers
  • 2,338 posts
  • Local Club: Amoc
Posted 30 December 2024 - 03:24 PM
I have a scrap subframe in next week if you need an off cut to weld on to your subframe?
Let me know and I can be extra carefull taking it off...
#7 DeadSquare
DeadSquare
  • 3,088 posts
Posted 30 December 2024 - 03:44 PM
This, is exactly the value of this site.  Helping other Mini owners.
#8 adman020
adman020
  • 21 posts
Posted 30 December 2024 - 05:29 PM
Wow some good ideas here - thanks all
bpirie1000 - if i could take you up on that offer that would be my preference - i'll pm you cheers
Also tagged with one or more of these keywords: suspension
