Dam8887 Bush
10 replies to this topic
#1 dotmatrix
dotmatrix
  • 400 posts
Posted 25 December 2024 - 10:51 PM
Hi.
can someone tell me where I can buy a new inner primary gear bush for a 1979 mini?
they seem to be sold out everywhere
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,279 posts
  • Local Club: Amoc
Posted 26 December 2024 - 07:11 AM
Find yourself a good machine shop.
Worth their weight in gold sometimes.
Especially if they will work with you for thismsort of thing.
More time spent now means less time road side waiting recovery.....
#3 Spider
  • 14,613 posts
Posted 26 December 2024 - 07:30 AM
Just to clarify,,,,,,
Is it a 998 or 1275 ?
When you say 'inner' bush, that's not a common term, so sorry, I'm not sure which one that is.
There is a front bush, which when fitted up is closest to the front of the engine (water pump end) and a rear bush, which is the top hat one closest to the flywheel.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,279 posts
  • Local Club: Amoc
Posted 26 December 2024 - 07:50 AM
https://www.somerfor...aft-drive-gears
Item number 18
Or
https://www.somerfor...eywords=Dam8887
BUSH-PRIMARY GEAR-FRONT 850,998,1098cc-'63-'92
One of those things that maybe need to make a few and offer a bulk buy if you can be bothered with the postage and the like..
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,713 posts
Posted 26 December 2024 - 01:44 PM
They are no longer available and have to be made to suit.
https://youtu.be/wYo...UuFI2BPSjGOia7s
Ac
#6 dotmatrix
dotmatrix
  • 400 posts
Posted 26 December 2024 - 11:01 PM
998
its the front bush. the one closest to the belt etc.
the other one I can find and buy, the one called top-hat. but I would be changing both
#7 dotmatrix
dotmatrix
  • 400 posts
Posted 26 December 2024 - 11:03 PM
Ac
thanks. I have seen both this and your other primary gear video (part 2). they are good.
I have access to a lathe, but obviously doesn't have the DEVA material. I have thought about asking you how much to rebush a primary gear for me, but sending it to and from Denmark where I live is an added cost
Edited by dotmatrix, 26 December 2024 - 11:06 PM.
#8 dotmatrix
dotmatrix
  • 400 posts
Posted 26 December 2024 - 11:12 PM
one thing I dont know about the top hat bush that can be bought from mini spares that is described as being silicon based is if its any good
#9 Spider
  • 14,613 posts
Posted 26 December 2024 - 11:17 PM
You'll see some results of from the Silicon-bronze bushes in these threads;-
https://www.theminif...ry-gear-damage/
https://www.theminif...3-primary-gear/
I've sent you a PM.
#10 dotmatrix
dotmatrix
  • 400 posts
Posted 27 December 2024 - 10:22 PM
Ac
by the way, in your part two video of rebushing that primary gear, it looks like you are using normal bronze for the front bush (furthest to the belt end) and that DEVA bronze for the top hat bush, but werent they both DEVA originally? is it ok to use normal bronze for that inner bush?
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,713 posts
Posted 28 December 2024 - 10:49 PM
In that video, that example the front bush is an extra high lead content lead bronze it’s not normal bearing bronze. The top hat bush is a minispare bush. These materials have proved perfectly reliable in the uk, I know this because I have machined hundreds of them, and none have returned.
I also offer genuine DEVA bushes, but the cost of these put most off as it’s more than double the cost of rebushing using the above method.
I also currently have a small stock of genuine original DEVA top hat bushes and the front bushes for the 1275 type gears. When these are gone there will be no more. I don’t sell these individually, only available when I rebuild your gear.
Here is an example of a genuine DEVA gear with custom bushes which I can supply when I rebuild gears for customers;
https://youtu.be/NTK..._xtxkW7ZiQ6xBjb
Ac
Edited by ACDodd, 28 December 2024 - 10:57 PM.
