Over Sills New Panels Or New Complete Floor ?
25 replies to this topic
#1 JPayne
JPayne
    Starting My Mini Up
  • 4 posts
Posted 18 December 2024 - 09:48 AM
Hi all.
I have a 1992 cooper which has had over / cover sills put on in a previous life , i have removed one of the sills and the damage is horrendous , i am presuming the other side will be the same , would it be easier to replace the complete floor or use full length replacement panels , there is also some rot on the heel board which would be rectified by a new floor..
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,186 posts
  • Name: Neil
Posted 18 December 2024 - 01:11 PM
The best thing to do is post up some pictures showing the full extent of the damage.
Changing the floor is a big job but if it’s only the inner sill to first flute where the damage lies you can buy good quality repair panels from M Machine.
The same applies to the heelboard, personally f the ends are really bad and there are signs of more rust on the heelboard I would change the complete thing.
I have some very good pictures detailing changing the inner sills to first flute and heelboard replacement in Project Paddy in my signature.
#3 JPayne
JPayne
    Starting My Mini Up
  • 4 posts
Posted 18 December 2024 - 01:57 PM
Thanks Neil , i will put a couple of pictures up..
I cant get my photos smaller than 2mb to upload ....
Edited by JPayne, 18 December 2024 - 02:52 PM.
#4 alpder
alpder
  • 566 posts
  • Local Club: MCR
Posted 18 December 2024 - 04:55 PM
Try XnView? Free image editor, cropper, resizer. Available as an appimage (i.e. no installation required). No ads. Runs on almost anything - Windoze, Mac, Linux, Android, IOS.
#5 cal844
cal844
  • 9,731 posts
  • Local Club: TFMOC
Posted 18 December 2024 - 06:38 PM
You'll need to use a photo hosting site and use a BB code (copy and paste into the message and it'll bring the photo up)
#6 JPayne
JPayne
    Starting My Mini Up
  • 4 posts
Posted 18 December 2024 - 07:59 PM
Attached File  new.jpg   53.2K   9 downloads
Attached File  new2.jpg   51.02K   6 downloads
Attached File  new1.jpg   56.72K   3 downloads
Thanks..
Edited by JPayne, 18 December 2024 - 08:35 PM.
#7 stuart bowes
stuart bowes
  • 2,602 posts
Posted 18 December 2024 - 09:28 PM
you need to know how far back it goes, ideally, try scraping off some of the floor coating working gradually away from the messy area, you might find the floor is just completely shot, or more likely it's contained mostly along both sides
in terms of what's 'easier' personally I think I'd rather repair in sections and not have to worry about alignment of the subframe fixing points, repair as-is and just keep things in the right place
on the other hand repairing in sections is obviously a lot of MIG welding whereas for the most part replacing whole panels can be done with a load of clamps and a spot welder.  downside being you have to brace things up and take a lot of measurements to make sure it's right
#8 sonscar
sonscar
  • 3,240 posts
Posted 18 December 2024 - 10:29 PM
That's not too bad,m machine do a floor/sill which will fix all that.Steve..
#9 PeterG
PeterG
  • 50 posts
Posted 18 December 2024 - 10:30 PM
Repair panels from M-Machine.  I had the same problem with previous owner fitted over-sills. I fitted half floor replacements from M-Machine. Lots of MIG welding. Lots of hours. Great result.
#10 JPayne
JPayne
    Starting My Mini Up
  • 4 posts
Posted 19 December 2024 - 11:11 AM
Thanks gents, it is pretty solid towards the middle , i will have a look at the m machine panels with the inner and outer sill..
#11 ADRay
ADRay
  • 139 posts
Posted 19 December 2024 - 11:31 AM
I had bad sills and a couple of small holes in the foot well and heel board, and decided to get the Heritage front-to-back 1/2 floors with sills attached.
It was over kill as I could have just replaced the sills and patched the holes.
Edited by ADRay, 19 December 2024 - 11:31 AM.
#12 sonikk4
sonikk4
  • 16,186 posts
  • Name: Neil
Posted 19 December 2024 - 03:31 PM
So if you go down the M machine inner sill to first flute route which I have done several times now there is a lot of work involved.
You will need to remove the companion bins and the floor crossmember. The heelboard if you go down the full panel replacement will need access in the companion bin area anyway so removing it will make life easier.
The heelboard is fairly straight fwd to replace, just a lot of spot welds, however I made a jig for mine before I removed it. ( I also changed the full boot floor amongst many other panels) The jig allowed me to ensure everything was in line and I had minimal issues fitting the subbie afterwards unlike on my lads car.
#13 coopertaz
coopertaz
  • 926 posts
  • Local Club: a-series-magpies
Posted 20 December 2024 - 12:32 PM
as said above def. remove companion bins and crossmember too makes life so much easier for not a lot of hassle
#14 s2ulk
s2ulk
  • 96 posts
Posted 19 March 2025 - 12:58 PM
Hi all, sorry to piggy back off JPayne's post but I have exactly the same dilemma at the moment and would welcome any views on this.  After removal of the oversills, my right hand inner sill area is a bit of mess with some holes towards the front and the rear and along the sill line.  My left hand sill (also had an over sill) seems to have survived better as the original outer sill was at least removed before the oversill was fitted.  However, the heelboard is blown out on the right hand side/getting crusty and the floor is pushed up a bit in the middle - likely from poor jacking.
Looking at Heritage and M Machine sill repair panels, it's not a great deal more to get a full Heritage floor. Hence I am contemplating whether just do a full floor, especially if it's actually less work overall.  Has anybody done a full floor but also just sill replacement/ repairs and is it significantly more work for a DIYer to do a full floor vs repair panels?
Some photos to follow.
#15 s2ulk
s2ulk
  • 96 posts
Posted 19 March 2025 - 01:14 PM
Photos of the floor and underneath:
