Mini Brake Light Bracket
3 replies to this topic
#1 Ol timer
Ol timer
  • 326 posts
Posted 10 December 2024 - 12:23 AM
I really am NOT having much luck fabricating a brake light switch bracket. anyone have one sitting around for sale ?
thanks in advance
Kevin
#2 Karl311
Karl311
    Starting My Mini Up
  • 1 posts
Posted 11 December 2024 - 11:28 AM
Please can you explain in details for me I got some part available but not sure what you are after
#3 mini-mad-mark
mini-mad-mark
  • 848 posts
  • Local Club: northants wot no brakes
Posted 12 December 2024 - 11:05 PM
Although the genuine bracket is a funky pressing with a swaged hole for the switch and a captive stud plus a 90 degree bend that goes into the slot to stop the bracket pivoting up and down, basically its a 90 degree bent bit of steel with a hole for the switch and another for a nut and bolt (more on that below)
Are you having trouble to visualise what the bracket should look like to knock up a copy - if so it looks like these:
https://www.somerfor... switch bracket
You can replace the captive stud with a nut and bolt and probably do away with the 90 deg bend gizmo and use an extra nut and bolt but that is fiddly, I know because.........
FYI you don't say if your pedal box is correct for these brackets -  I have fitted a pedal switch to an early pedal box  - the pedal boxes are smaller (later ones are extended to incorporate the bracket as shown)  - the bracket had to be a bit different but its do-able. That used two small M5 nuts/bolts to hold it in place and stop it pivoting
Edited by mini-mad-mark, 12 December 2024 - 11:10 PM.
#4 Ol timer
Ol timer
  • 326 posts
Posted 18 December 2024 - 08:53 PM
gday guys. sorry for the late delay. I managed to get the switch sorted. I used a microswitch with a long arm and glued.it into place. works a treat
