Old Inner Wing Vs New Inner Wing
1 reply to this topic
#1 CBJ805T
CBJ805T
  • 438 posts
Posted 27 November 2024 - 01:13 PM
Hi,
I'm in the process of persuading my new inner wings to fit and noticed some differences between the new wing and the original (1984)
A - The Bottle Holder and Bonnet Stay - I can't find them as replacement panels, so I'm going to recycle the originals - Any concerns?
B - The new wing has 2 newfangled brackets - what are they for? do I need to remove them, as they look like they'll clash with the original bottle holder
C - Loom retaining 'tags' - these are missing from the new panel - can you buy these or just make them up from sheet steel?
D - The new wing has several holes around where the loom would run - what are these for? are looms retained in a different / better way on later models?
https://www.amazon.c...BYUIfDkO7LcALEH
https://www.amazon.c...JK0y6SSvHps3bar
thanks
Chris
#2 gaspen
gaspen
  • 875 posts
Posted 27 November 2024 - 02:34 PM
A : just copy the position from the original panel and weld them to the new. A spot welder is helpful here
B : I believe they are for the ECU for the MPi/Spi engines, you won't need them for a carburetter model.
C : you can make them from steel sheet and spot weld. I've used openable cable-ties instead
D : I don't really what those holes for, I just welded in all the holes which aren't there on the original panel and hammered flat those bumps also
Attached File  IMG_20210707_093217.jpg   47.57K   1 downloads
