Riley Elf (Mk3) Rear Seat Belts
3 replies to this topic
#1 1958jcb
1958jcb
    Starting My Mini Up
  • 2 posts
Posted 22 November 2024 - 04:07 PM
Has anyone added Rear Seat Belts to an Elf?
If so where did you anchor them?
#2 mab01uk
mab01uk
  • 12,370 posts
Posted 22 November 2024 - 06:44 PM
These are the 5 mounting with captive threaded nuts (links below) used in later Minis which would also fit a Mk3 Elf.
The rear bulkhead mounting goes low down on the rear bulkhead inside the boot.
The only problem is the plates need welding in position so not ideal unless part of a restoration.
Somerford
MOUNTING KIT- REAR SEAT BELTS (5 x WELD-IN BRACKETS) :-
https://www.somerfor...eld-in-brackets
Minispares
SEATBELT CENTRE MOUNTING PLATE ON REAR BULKHEAD:-
http://www.minispare...3R.aspx|Back to
SEAT BELT ANCHOR MOUNTING POINT REAR LH:-
https://www.minispar...assic/MS22.aspx
SEAT BELT ANCHOR MOUNTING POINT REAR RH:-
https://www.minispar.../ALJ360130.aspx
Edited by mab01uk, 22 November 2024 - 06:53 PM.
#3 humph
humph
    How bad can it Be?
  • 1,088 posts
Posted 23 November 2024 - 12:09 AM
I have rear seats in my Elf that were fitted using the Somerford kit Mab links too above. Main issue is that the rear pillars are wider on the Elf than the later minis because the Elf has the smaller rear screen from the mk1 Mini (but the larger side windows from the later Mini). So to fit ours a plate was welded to the rear of the front end of the mounting bracket to extend it. Second problem is that the C pillar trim needed modifying, In fact I think we made new. I went static belt to avoid the bulky mechanisms, but if they’re to be used regularly by different people I’d go inertia reel.  Alternatively fit the three lower brackets and go for lap belts.
Edited by humph, 23 November 2024 - 12:20 AM.
#4 1958jcb
1958jcb
    Starting My Mini Up
  • 2 posts
Posted 24 November 2024 - 12:29 PM
Many thanks for your replies guys.
