Clearing all my a series parts.
Photos of everything available.
Collection near Dorking, or can post.
All prices are ono.
Alloy rocker cover.
Has had the fins removed off the top and 3 breathers added. In excellent condition.
Looks very different and is nice and light!
£100
TCK SC billet 7 port inlet manifold. Nice manifold. Flange is for an AT power TB.
£450
Billet 7 port head, better than new.
The head has just come back from TCK in a better than new spec. It’s had all new seats, guides, valves and valve springs and is built ready to bolt on. TCK also put helicoils in the rocker post stud holes and made some steel spreader shims to go under the rocker posts. The head is dry decked with brass plugs and the end plate has been adapted for a dry deck fitting.
£2500
12g940 head, needs a repair. Face has a few spots that need a little welding.
£110
Metro thermostat take off. Painted in VHT wrinkle paint.
£15
5L of millers CTV unopened
£40
Verto slave kit, lightened slave, Ti rod, lightened centre bolt, titanium over centre adjustment nuts and minisport HD arm.
£100
Gt1752 turbo, all trimmed back and the compressor side is polished.
£150
Forged omega +40 18cc dish pistons on Saenz conrods. Best you can get!
£1350
Specialists components tough crank used for around 3000 miles. These are nitrided, wedged and bladed.
£1000
Fusion top mount t3 fit turbo exhaust manifold and downpipe. Suit a gt17. Ideal for 7 port heads.
£500
Lightweight brise starter motor. Hardly used.
£250
RTS clutch and spares 998/1275 spring ap plate, med lightweight flywheel. Balanced at KAD.
£400
MED belt drive. 2 used belts, one new. Has been modified with drains behind the seals. These were renowned for leaking oil due to poor design. This has been solved and doesn’t leak!
£300
MED trigger bracket and sensor
£50
Avonbar phase 2 cam with followers good used condition.
£200
Avonbar phase 2 cam new. With followers and oil pump.
£325
Nos lightweight med clutch kit pre verto orange diaphragm.
£400
Standard drop gear casing (nos)
£80
Wok, comes with a solid engine mount fitted.
£50
Low profile remote oil filter take off with AN fitting
£20.
MED straight cut roller drop gears
Excellent condition have only been used for 10 miles. 0.958:1 ratio
£300
Owens fabrication billet gear linkage. Comes with gear knob and adjustable linkage bar made from 4130 tubing.
£425
Straight cut box with 3.44 x-pin diff NOS never used gearset.
£1500
MED dog box, best of everything in it! As new.
£2900
Could split this up has Quaife ATB, MED pinion support, SC CWP.
1310cc block, dry decked, under crown cooling, centre main strap
£1200
Metro turbo block STD, will need at least a hone.
£395
Mk2 fibreglass bootlid
£60
ARP 11 stud head bolt set, used.
£90 (sold)
MED 4 bolt main block, 1293. Bare block, as new. Was built up but never ran. £1200 (sold)
MED 1.3.1 roller rockers
Good used condition
£250 (sold)
MED 300m driveshafts
£210 (sold)
Vernier duplex cam gears and chain. Fitted but never ran.
£95 (sold)
MED pushrods
£60 (sold)
SH engineering water pump blank/take off. 32mm.
£35 (sold)
DSN dizzy blank
£12 (sold)
Swiftune competition oil pump and ti bolts.
£60 (sold)
Lightweight alternator
£100 (sold)
Lightweight alternator with bigger pulley and Titanium nut.
£120 (sold)
Cometic dry deck MLS gasket. Can be used to convert to dry deck without plugging head/block. Or great for better gasket integrity on a dry deck.
£95 (sold)
Nos (built never ran) omega op120 (+20) 1293 forged pistons on rods.
£550 (sold)
MED management damper pulley
£120 (sold)
Lightweight drop gear casing
£100 (sold)
New (trial fitted) 1:1 Jack knight roller drop gears
£300 (sold)
7 Port Turbo Engine Breaking And Other Go Faster Engine Bits!
jonny f
, Nov 21 2024 03:13 PM
1 reply to this topic
