Shooter
Ammeter, Volt Meter Or What?
Posted 21 November 2024 - 07:04 AM
Shooter
Posted 21 November 2024 - 07:50 AM
A voltmeter is easiest to fit. An Ammeter if wired as per the original way is dangerous and requires harness modification. But there is a safer way of doing it but I forget what is needed. Oil pressure is a good one.
Posted 21 November 2024 - 08:15 AM
An ammeter needs full battery cuurent and sized wore to suit, not something you want on your dash.
Posted 21 November 2024 - 08:44 AM
OIl , Volts , Vacuum . temp
Vacuum can tell you a lot about the engine condition & potential problems .
as above ammeter wiring can be nasty unless done remotely .
oil temp is also useful esp with gearbox using the same oil .
Edited by sledgehammer, 21 November 2024 - 08:45 AM.
Posted 21 November 2024 - 09:35 AM
The two must haves for me personally is Oil Temp and Oil Pressure, currently i have Oil pressure and Vacuum, (purely because i had the guage and gap to fill before i get my oil temp plumbed in)
I think the other useful gauge would be AFR in leu of Vacuum gauge.
Posted 21 November 2024 - 10:38 AM
As above stay away from ammeter . If your still running a dynamo the volt gauge could be useful . My personal preference is vacuum gauge.
Posted 21 November 2024 - 10:59 AM
I think a wide band gauge is a good investment as you can see if the mixture is too rich or weak, both potentially disastrous for an engine. They don't look retro but you could put it out of site and only using it during tuning.
Also I think a clock is really useful, I find it surprising how many times I glance at it during a journey.
Posted 21 November 2024 - 11:44 AM
I agree with fitting a clock. It's great to know what time it is to see if you can stop on your way to get somewhere on time.
Posted 21 November 2024 - 08:21 PM
Shooter
Posted 21 November 2024 - 08:31 PM
Yes.
Posted 22 November 2024 - 01:40 AM
Posted 22 November 2024 - 07:37 AM
Shooter
