Has Anyone Made A Rear Seat Pass Through?
14 replies to this topic
#1 -Lost-
-Lost-
  • 17 posts
Posted 18 November 2024 - 02:45 AM
I'm not planning on actually using the rear seats, they will just be a parsel shelf. I was thinking it might be helpful to be able to fold the back down to fit large things in the boot. Has anyone done or seen anything like that?
#2 Quinlan minor
Quinlan minor
  • 1,128 posts
  • Local Club: LSMOC
Posted 18 November 2024 - 04:02 AM
Whatever you do, don’t let the DVLA know!
#3 mab01uk
mab01uk
  • 12,263 posts
Posted 18 November 2024 - 10:56 AM
Radford made a Hatchback Mini with folding rear seat:-
https://www.theminif...de-ville-ÂŁ240k/
#4 PoolGuy
PoolGuy
  • 834 posts
Posted 18 November 2024 - 11:14 AM
:D
#5 mab01uk
mab01uk
  • 12,263 posts
Posted 18 November 2024 - 12:14 PM
However there will be no problems with any modifications to the bodyshell with the UK DVLA as I think the Mini owner is based in the USA....
Edited by mab01uk, 18 November 2024 - 12:15 PM.
#6 Designer
Designer
  • 532 posts
  • Local Club: 8 Iron
Posted 18 November 2024 - 12:35 PM
I don't think that applies in New Jersey. Unless they have an equivalent department that manages to screw things up for classic car owners.
#7 -Lost-
-Lost-
  • 17 posts
Posted 18 November 2024 - 06:51 PM
Yeah, I'm in New Jersey, so nobody here is inspecting my car. That hatch looks incredible, but more work than I had in mind.
#8 mab01uk
mab01uk
  • 12,263 posts
Posted 18 November 2024 - 07:40 PM
You could do the conversion as you suggested but without the hatchback but the rear bulkhead and parcel shelf in a Mini is an important part of the bodyshell structure so if all or a large part is removed suitable extra metalwork must be added to take its place. It is also a firewall between passengers and the fuel tank. A rear roll cage with braces to the rear wheel arches as used in race and rally Minis might also be a good addition for adding back any lost strength to the shell.
Mini Rear Roll Cage - with diagonal:-
https://www.minispor...-roll-cage.html
Edited by mab01uk, 18 November 2024 - 07:42 PM.
#9 absx2
absx2
  • 894 posts
Posted 18 November 2024 - 08:21 PM
I used to put my 12 foot long fishing rod in my mini in the boot by flipping down the back seat having removed the cardboard from the rotodip hole.
The rod was in two pieces of course but I used to get the odd funny look when people noticed a huge fishing rod coming out of a mini boot :)
#10 -Lost-
-Lost-
  • 17 posts
Posted 19 November 2024 - 12:58 AM
The extra bracing added is really what I'm curious about. I figured I would need maybe a cross member up top and maybe one lower down?
What hole did you have the fishing pole through? I don't have any holes through there.
#11 stuart bowes
stuart bowes
  • 1,952 posts
Posted 19 November 2024 - 10:06 AM
earlier cars had a hole in the back seat like there is in the front bulkhead which they used when they rotodipped the shell
later cars didn't have it, mine doesn't either
Edited by stuart bowes, 19 November 2024 - 10:06 AM.
#12 absx2
absx2
  • 894 posts
Posted 19 November 2024 - 05:19 PM
650b1058be1ed876caefabc1_6442b1706909425
You can see the hole in this picture covered by cardboard from inside.
Mk1 to 3 minis had them up to about 1975.
It wouldn`t be the hardest job to copy if you were good with sheet metal work.
That`s not my car by the way :)
Edited by absx2, 19 November 2024 - 05:22 PM.
#13 DeadSquare
DeadSquare
  • 3,028 posts
Posted 19 November 2024 - 05:43 PM
Using a modified rear seat from a Countryman, a got a 6'6" flat load space in a Riley Elf.
All the windows were darkly tinted.
#14 -Lost-
-Lost-
  • 17 posts
Posted 19 November 2024 - 11:42 PM
My bulkhead has an oval pressed in right at that spot, I guess they still kept that shape but just didn't cut the hole through?  Mine's a 74 so it must have just missed the cutoff.
#15 imack
imack
  • 2,016 posts
Posted 20 November 2024 - 09:19 AM
The rear bulkhead hole was deleted (along with other minor changes) at the end of 1972 when the early mk3 with the round tunnel for the remote gearshift changed to the late mk3 with the square tunnel for the rod change gearshift.
