Looking for someone with good electrics knowledge that can help me diagnose an issue as I have a wiring issue I need to fix.
ISSUE:
- With the ignition on and headlight light switch completely off , The side lights on the driver side stay on both front and rear
- If the ignition is off and side lights are turned on with the switch, The Passenger side light stays on both in front and rear
- When engine is started and lights are off, The side lights on the driver side stay on both front and rear (Same as Point one above)
- When the engine is on and light switches are turned on in any position, everything works as expected with no issues.
I have attached some images to help explain.
Switch off, Ignition on.jpg 56.58K 1 downloads
Switch on, Ignition off.jpg 80.91K 0 downloads
WHAT I'VE DONE SO FAR TO DIAGNOSE:
- Took off all the lights and made new connections to make sure there wasn't any bad connections
- Checked all fuses behind the dash and under the bonnet
- Replaced the headlight switch
- Tried disconnecting the spot lights and indicators and checking to see if it still happened when these were disconnected
- Switched the headlights around to see if it was an issue with the unit, It wasn't. Issue still happens the back right light so cant be an issue with the headlight unit itself.
NOTE: I am very bad at understanding electrics so please if you have any advice I will not be offended so don’t be afraid to explain step by step as if I am a 5 year old!
Edited by boboleary777, Today, 11:19 AM.
