Distributor Machine
83 replies to this topic
#76 gaspen
gaspen
  • 916 posts
Posted 09 February 2025 - 06:42 PM
Good work !
Really getting somewhere.
Most distributors that have 2 springs will have 3 angles to the 'curve'.
Considering curve A in your diagrams, the first steep part is the lighter primary spring, the lesser angle is the heavier secondary spring and the plateau is when it's reached maximum advance.
Curve B has a sing spring or 2 matched springs.
Curve A on both diagrams are the centrifugal advance. The two parallel lines are the minimum and maximum values so it allows +/- 2 degrees tolerance
Curve B is the vaccum advance.
For example I have here the 25D 41026 dizzy from my850 with two different springs. I always thought that it works like I draw it on the diagram below
Attached File  20250209_185515 (1).jpg   33.86K   0 downloads
Attached File  41026.jpg   79.92K   0 downloads
#77 Spider
  • 14,772 posts
Posted 09 February 2025 - 07:25 PM
Sorry, I thought you wanted assistance in interpreting the curves.
Yes, published Lucas curves are +/- 1 degree. While Vacuum can be plotted on a graph it's not normally done that way, just the figures for it's characteristics. It's not normally plotted as the vacuum can is only part of that 'story', the other part being how it's ported to the carb and it's characteristics on the particular manifold and engine it's fitted to.
#78 gaspen
gaspen
  • 916 posts
Posted 09 February 2025 - 07:54 PM
Yes, indeed, but you referred to curve B as a dizzy with a single or 2 matched springs which confused me  :shifty:
I guess the 2nd break on the 41254 curve is because of a "special mixture" of the two springs.
Edited by gaspen, 09 February 2025 - 08:03 PM.
#79 68+86auto
68+86auto
  • 861 posts
  • Local Club: Queensland Mini Car Club
Posted 10 February 2025 - 06:28 AM
I know you are bored
Not at all.
#80 gaspen
gaspen
  • 916 posts
Posted 16 March 2025 - 04:24 PM
First light in the Universe  ;D
https://photos.app.g...v8S1TKpDj8iYJ68
Attached File  20250316_142321.jpg   31.82K   1 downloads
Edited by gaspen, 16 March 2025 - 06:05 PM.
#81 68+86auto
68+86auto
  • 861 posts
Posted 20 March 2025 - 08:28 PM
This may interest you. Jeff Schlemmer has removed all the internals from one of his sun machines and is converting it to electronic speed control as well as an LED conversion. All the original internals have been removed as they have proven to be unreliable (he uses these machines every day). He's using "wireless LEDs". I think the sun machine has an arrow shaped window that the light goes behind, originally a dim neon.
Attached File  FB_IMG_1742501434386.jpg   39.79K   3 downloads
Looks to be something like this: Attached File  Screenshot_20250321_061242_Opera.jpg   36.43K   4 downloads
Attached File  FB_IMG_1742502425332.jpg   66.89K   3 downloads
Edited by 68+86auto, 20 March 2025 - 09:56 PM.
#82 gaspen
gaspen
  • 916 posts
Posted 21 March 2025 - 07:31 AM
Looks to be something like this: attachicon.gif Screenshot_20250321_061242_Opera.jpg
Thank you, that sound interesting  :shifty:
Do you have a direct contact to him ?
Edited by gaspen, 21 March 2025 - 07:42 AM.
#83 68+86auto
68+86auto
  • 861 posts
Posted 21 March 2025 - 12:03 PM
This is where he has been posting about this conversion: https://www.facebook...01609380266329/
This is his website: https://www.advanceddistributors.com/ (his business is rebuilding Lucas distributors)
The conversion is still a work in progress so it's not tested properly yet.
Edited by 68+86auto, 21 March 2025 - 12:06 PM.
#84 gaspen
gaspen
  • 916 posts
Posted 24 March 2025 - 08:35 AM
Damn...  O_O
Attached File  Képkivágás.JPG   19.36K   0 downloads
