Distributor Machine
88 replies to this topic
#46 Spider
  • 15,108 posts
Posted 23 November 2024 - 02:57 AM
I know that different drives and AC or DC both have advantages and disadvantages. Certainly finding a disused Tread Mill as 68-86 has suggested is appealing if on a tight budged. It might needs a few mechanical speeds, eg, stepped pulleys or a gearbox to adequately cover the range of speeds needed (mine goes to 5000 RPM, but I'd suggest you'd want a minimum of 4000). While most of the 'action' happens below 2000 (Distributor) RPM with the advance mech, it's good to be able to check for bounce, sucking from higher speeds, dwell variation at high speeds and even that the rotor button has enough swipe angle at these higher speeds.
I know mine is DC, I can't recall if it's 12 or 24V, it used a PWM Controller. It tales back EMF from the motor if it over speeds and uses that to brake and tightly regulate it's speed.
I think the type of Slip Ring you've described is referred to as a Flat Face Slip Ring. You can find Slip Rings of Flat Face and Cylindrical design. in just about any Automotive Alternator and most are 2 pole ;D
#47 68+86auto
68+86auto
  • 1,006 posts
  • Local Club: Queensland Mini Car Club
Posted 23 November 2024 - 07:15 AM
Treadmill motors go to about 6000rpm. I'm not sure of the minimum speed but it's quite low. I have one on a drill press but it has a reduction.
I say an AC motor simply because that generally means mains voltage. AC or DC it doesn't matter but you'll find that when dealing with motors in the 100s of watts, it's cheaper to use a higher voltage than 12v. Both the motors and controllers are cheaper. A 12v motor around 500w is going to need a controller capable of around 50a which is quite high and becomes expensive.
Just have a look around and see what you can find new/used for the right price.
Edited by 68+86auto, 23 November 2024 - 07:15 AM.
#48 Steam
Steam
  • 817 posts
  • Local Club: Victorian Mini Club
Posted 23 November 2024 - 09:00 AM
AC or DC (High voltage rock and roll :-) ) doesnt make much differemce. If you are using a standard coil then you will need a battery anyway and PWM controllers are cheap enough on ebay.
Ac motors are more flexible but the speed controllers are more expensive, as are the motors.
#49 gaspen
gaspen
  • 977 posts
Posted 23 November 2024 - 09:30 AM
I started to sketch-up the machine in Sketch-up  :proud:
On TEMU I can find flanged disc in many sizes. One attaches to the motor's shaft, the upper I will slot to accept the dizzy's drive. Beetween the two flange I can install the degree wheel.
The motor I can find is a 24V/150W, but is also have 12V versions. These are small, cheap and reliable, as they said.
My Makita cordless drill  can easily rotate the dizzy so I think 150-200W will be enough.
Beetween the motor housing and the degree wheel I will have ~25mm room for the slip ring. A flat facedslip ring would be easier to setup.
Attached File  1725442063514-13cafd740b8a4dcbbffa8299d89aa959-goods.jpg   34.39K   0 downloads
Attached File  Sad59d6af6463400fadba82d82bd3d5457.jpg_960x960.jpg   23.65K   1 downloads
Attached File  elosztó.jpg   20.32K   1 downloads
#50 gaspen
gaspen
  • 977 posts
Posted 23 November 2024 - 09:44 AM
I have a small 12V power supply but it can be loaded with 2 Amps only. Last week I've put together a basic ignition system on the bench just to see if it works or not.
Of course I will need an other power supply for drive the motor but to blink a LED it could be enough
And as I wrote this I say to myself : why don't I use one 12V power supply for both task ?!
Edited by gaspen, 23 November 2024 - 04:39 PM.
#51 gaspen
gaspen
  • 977 posts
Posted 23 November 2024 - 05:25 PM
Use a mains (AC) powered motor and a speed controller.
Alternatively a common motor to find is a treadmill motor which can usually be found for free. They are 180V DC. If you don't mind messing with all the settings you can use the treadmill control panel. It will even regulate the speed. Some cheap basic treadmills have a simple controller with a potentiometer but they are much harder to find. A treadmill motor is way more than enough power but the price is perfect.
For the slip ring assembly, simply have a google search. I get a lot of results from Aliexpress which look like they would work. Example https://www.aliexpre...2xoCPfwQAvD_BwE
I have found the specs of this slip ring. It's rated for max. 1000 RPM
Attached File  Képkivágás.JPG   22.49K   0 downloads
Edited by gaspen, 23 November 2024 - 08:45 PM.
#52 Spider
  • 15,108 posts
Posted 24 November 2024 - 06:26 AM
If you were to use a slip ring from an Automotive Alternator, there are generally rated to 12000 RPM +.
#53 gaspen
gaspen
  • 977 posts
Posted 24 November 2024 - 07:45 AM
Yes, I just have to find one which fits to my design.
Maybe this ?
Attached File  2a1ec19b30aad4809e3c5bb0d35278e0c74af1f5_original.jpeg   21.79K   0 downloads
#54 Spider
  • 15,108 posts
Posted 24 November 2024 - 04:37 PM
Maybe this ?
Yes, looks good to me, though I was thinking you could get it from a used alternator for next to no cost.
#55 gaspen
gaspen
  • 977 posts
Posted 24 November 2024 - 06:04 PM
Maybe this ?
I don't have any used alternator, but I am working in a truck workshop where I can order parts from a local supplier. I found some cheap rings and brush boxes also, tomorrow I will order these.
Other idea that I'm thinking of to drive the degree wheel on half speed instead. I will measure the engine RPM from the coil so it would be easier to draw the curve.
This complicates the design but I need some brainstorming  :D
Attached File  Képkivágás.JPG   40.89K   2 downloads
Edited by gaspen, 24 November 2024 - 06:06 PM.
#56 Spider
  • 15,108 posts
Posted 24 November 2024 - 06:38 PM
There's nothing really wrong with your proposal, but it does unnecessarily add to the complexity of it.
I'm a great believer in KISS when designing and making stuff - Keep It Simple, Stupid.
And it'll keep you sharp when reading it. I would suggest doing it all in distributor angles and speeds.
#57 gaspen
gaspen
  • 977 posts
Posted 25 November 2024 - 10:50 AM
Okay, okay
This is what I've purchased for ~10USD
Attached File  20241125_105503.jpg   55.65K   0 downloads
#58 gaspen
gaspen
  • 977 posts
Posted 01 December 2024 - 08:06 PM
Today I've made a fixture for the dizzy and put together a proto test "bench". Not a big step, I just see the opening/closing degrees. This measurement shows that the four "sparks" are  within ~1° tolerance. Looking at the Lucas's curves which allow +/-2 ° tolerance it seems good to me.
Maybe I will make it a little simpler and discard the blinking-light-on-the-disc feature from the plan. As 68+68 suggested in post #34 : if I have 4 stable sign 90° from each other I could us a normal stroboscope to measure the advance.
https://photos.app.g...zngywMBb61G6Nw9
#59 Spider
  • 15,108 posts
Posted 02 December 2024 - 02:56 AM
Good work so far !
You'll need something 'faster' than a normal bulb, they are too slow to ramp up and too slow to ramp down in brightness. You need something, like a Xenon or LED that's 'instant'. But at least the bulb shows it works in principal.
#60 gaspen
gaspen
  • 977 posts
Posted 15 January 2025 - 05:33 PM
After some break I am back in the project. I've collected some components as I made some tiny modifications in the plans. Details later as I start to develop the machine.
One thing that I don't understand yet. There are two types of machine regarding the measurment.
One of them shows a lighting arc of which "length" is equal to the Dwell-angle (1st pic)
The another only points an arrow to the actual degree valu on the scale. (2nd pic) On these macine there is a separate Dwell-meter
What could be the difference in the two measurment ?
Attached File  ZVP1-110513-03.jpg   37.01K   0 downloads
Attached File  Képkivágás.JPG   79.25K   0 downloads
