Distributor Machine
170 replies to this topic
#31 gaspen
gaspen
  • 1,194 posts
Posted 20 November 2024 - 09:03 PM
So I was thinking more !  I am pretty deep in this discovery but now I understand how does it work
I know it is not as new for you  as for me    :D
The machine doesn't need to "watch" each cylinder separately for Dwell value - and it can not do it.
When the contact closes at 1st cylinder the ligth on the machine illuminates from 0 to 50 degrees (example) and turns off  beetween 51 and 90 degrees.
The next lobe on the cam will do this again but on the next quarter of the scale as the whole assembly rotates. I see all lights at the same time because it is so fast that my eyes can not senses the difference
#32 Spider
  • 15,850 posts
Posted 20 November 2024 - 10:12 PM
I think I'm am following your question here but not 100% sure, correct me if this is not what yr after.
Here's a pic of a Distributor under test;-
You can see here the points are closed (Dwell) for 370 (the fading is due to the action of the camera, to the eye it appears solid). It also has 60 advance at 1950 RPM.
This should be the same in all 4 quadrants. If it's not then it can indicate some of the issue mentioned in my previous post.
#33 gaspen
gaspen
  • 1,194 posts
Posted 20 November 2024 - 10:53 PM
There is no question here I just learned how the machine measure and displays the Dwell angle  :proud:
My numbers (0-50 and 51-90) are only theoretical, not actual numbers. My 0º equal 130º in your machine, where the contacts open, my 50º is your 93º where the contact closes and so on
I studied the operation of that french machine, I've found forums about it. Common practice that they replace the original 400V strobe tube for 12V LED's
Next I have to learn how it light up a LED with an open circuit. I bet there is a simple solution  :D
#34 68+86auto
68+86auto
  • 1,477 posts
Posted 21 November 2024 - 01:05 AM
As you've found, most used a strobe of some kind. These usually didn't display the points open time using the light since they only flashed once for each cylinder. Some LED conversions work like that and some show the dwell as the unlit section. Some conversions are switchable. The dwell doesn't really need to be seen like this as what you are looking for is that all four firing points are 90 degrees apart. If these are even, the dwell will be too. It does help to display the dwell though as it is clearer than looking at an analog dwell meter and never will need calibration due to how it works.
Many people change to LED simply because they find the strobe dim, this depends on the machine as some are better than others.
I'd suggest reading the manuals of a few different machines.
Here's two which are both the single strobe type, not LED
https://www.starchak.../sun manual.pdf
https://archive.org/...raph-410-manual
I have a page on an LED type which I can scan later.
My machine is one of the last "old" distributor machines made so uses an LED to display the points open time (dwell being the unlit section).
My machine has a 15v transformer which is rectified to about 20VDC. To power the strobe circuit and simulate a load for the resistance test, this goes to the points thru a resistor. The strobe supply is fed from the points wire. When the points are closed it's at 0v, when they open it's at 20VDC. It's just like an ignition system but a resistor instead of a coil. I haven't pulled my machine that far apart but I'm told on the disc it has the led and a transistor which are powered inductively.
I have the schematics for a couple of strobe type machines, no LED ones. They all use parts which are hard to get so it's probably best to design a new board and for an LED.
Edited by 68+86auto, 21 November 2024 - 01:13 AM.
#35 gaspen
gaspen
  • 1,194 posts
Posted 21 November 2024 - 08:36 AM
Yes, that makes sense, thanks for simplifying   :proud:
From practical view : these machines have the light fixed on the rotating disc, I guess the wires go there through some kind of slip ring. There is many types out there, I can find a suitable piece
Attached File  original.jpg   22.14K   0 downloads
Another idea came to mind when I woke up this morning : what if I place 4 fixed LEDs around the rotating disc, placed 90-degrees to each other ?
Attached File  elosztó.jpg   11.14K   0 downloads
#36 Spider
  • 15,850 posts
Posted 21 November 2024 - 09:55 AM
My machine does have a slip ring, but only a single LED.
I think you'd only want one LED.
#37 gaspen
gaspen
  • 1,194 posts
Posted 21 November 2024 - 10:49 AM
Maybe I was not clear enough  :shy:
Yes, your machine uses the slip-ring with one LED  and that LED will light up 4 times in 1 rotation.
I am not sure how will I install that (or any) slip-ring to my machine so I thinking about different solutions also.
The whole setup is similar if you'd use 4 stroboscope on an engine with 4 marks on the flywheel.
The LEDs on my sketch are fixed on the base of the machine, they won't rotate just pointed to the rotating disc. They are switched on/off by the contact in the dizzy *
On the base there is also 4 fixed markings** (line or arrow, it"s all the same)
The rotating disc has only ONE marking
The marks on the base will be illuminated by the LEDs at the same moment when the mark on the rotating disc approach to the very same spot.
* I am thinking about controlling them by 12V NO/NC relay but I am not sure that the a mechanial relay is fast enough for this operation.
** Of course I will need more markings for the advance checks, but above I described the initial setup of the machine. I mean : does it work at all ?!  :D
#38 68+86auto
68+86auto
  • 1,477 posts
Posted 21 November 2024 - 11:30 AM
Most of the machines which use a strobe don't spin the strobe from what I understand. I'm not really sure how they work as I haven't seen one in person.
A relay would be unsuitable
This is a simple diagram of my machine.
Attached File  image_2024-11-21_212221799.png   50.17K   3 downloads
When the points are closed, the voltage is low. When they are open the voltage goes past a point where a transistor tells the LED to turn on.
All of this is the part that I never got around to designing for the machine I was making. I intended to possibly just use a timing light and setup spark plugs. Not ideal but it was what I was going to start with and progress from there. I had motor coupling issues and before I sorted it out I found a machine so never completed my diy one.
Edited by 68+86auto, 21 November 2024 - 11:33 AM.
#39 gaspen
gaspen
  • 1,194 posts
Posted 21 November 2024 - 11:41 AM
Maybe a MOFSET controller will solve this... ?
In this description you can see some details : the rotating disc has a thin slot where the strobe-tube (which converted to LEDs) lights upwards.
The light source is rotates with the disc, also you can see the slip-ring
(Google Translator needed)
Souriau, banc d'allumage
#40 68+86auto
68+86auto
  • 1,477 posts
Posted 21 November 2024 - 12:11 PM
Do you have electronics design knowledge?
I repair electronics when I need to but can't design them. I wish I could.
Edited by 68+86auto, 21 November 2024 - 12:12 PM.
#41 68+86auto
68+86auto
  • 1,477 posts
Posted 21 November 2024 - 12:41 PM
I just noticed I didn't put the modified diagram I made. VBB is the DC Supply +
Attached File  distmachine.jpg   32.14K   0 downloads
Edited by 68+86auto, 21 November 2024 - 12:41 PM.
#42 Spider
  • 15,850 posts
Posted 21 November 2024 - 04:45 PM
I need to think about your proposal some more, but at a 'glance' if the LEDs are stationary, then the degree wheel would need to spin, so how do you read it when it's wizzing around at 2000 - 3000 RPM ?
I recall the circuit inside mine is very simple, if I recall, the 'lamp driver' consists of no more than a power supply for the LED, a slip ring (which I can't recall is single or double pole) and the LED.
#43 gaspen
gaspen
  • 1,194 posts
Posted 22 November 2024 - 09:31 AM
Okay, just ignore it, I  overthought it  :D  I will go for the slip ring version with one LED on the rotating disc
Now I hunting for a good 12V motor but it is harder to find that I imagined.
There is more 24V motor, but I will need a power supply
Most slip rings have the contacts on their sides. How do you call in english which have the contacts on the face ?
Edited by gaspen, 22 November 2024 - 11:31 AM.
#44 68+86auto
68+86auto
  • 1,477 posts
Posted 22 November 2024 - 01:19 PM
Use a mains (AC) powered motor and a speed controller.
Alternatively a common motor to find is a treadmill motor which can usually be found for free. They are 180V DC. If you don't mind messing with all the settings you can use the treadmill control panel. It will even regulate the speed. Some cheap basic treadmills have a simple controller with a potentiometer but they are much harder to find. A treadmill motor is way more than enough power but the price is perfect.
For the slip ring assembly, simply have a google search. I get a lot of results from Aliexpress which look like they would work. Example https://www.aliexpre...2xoCPfwQAvD_BwE
Edited by 68+86auto, 22 November 2024 - 01:21 PM.
#45 gaspen
gaspen
  • 1,194 posts
Posted 22 November 2024 - 01:46 PM
Well my mind was locked to the 12V system as the car uses this voltage  :D
Here we have 230V AC system
Why is an AC motor better ?
Edited by gaspen, 22 November 2024 - 02:09 PM.
