Crank Journals Worn By 0.005" Regrind Needed?
16 replies to this topic
#1 babsbrown
babsbrown
  • 459 posts
Posted 15 November 2024 - 10:45 PM
Evening guys,
As above really? I know the cranks typically get reground to the next bearing size e.g 10 thou 20 thou etc...
But at what stage of wear is indicative of a regrind? I have 5thou average of deviation from the standard 1098 size of 1.625. They're measuring 1.620" would that suggest a regrind is required?
Thanks, Babs
#2 Spider
  • 14,849 posts
Posted 15 November 2024 - 11:50 PM
That definitely needs a grind.
Be sure to have it done in a grinder that holds the crank between chucks, not one of those rubbish Prince Chassis grinders.
Ask them to Index it while they have it up in the grinder.
#3 babsbrown
babsbrown
  • 459 posts
Posted 16 November 2024 - 12:49 AM
Thanks mate, to be honest there's only one place that does it near me. I'm not sure what machines they have I'll have to double check. They want £180 for the Job mind.
Pardon my ignorance but what does indexing mean please?
Cheers,
#4 babsbrown
babsbrown
  • 459 posts
Posted 16 November 2024 - 12:52 AM
Attached File  20241115_100929.jpg   39.65K   10 downloads
This was the measurement i took
#5 Spider
  • 14,849 posts
Posted 16 November 2024 - 02:25 AM
Cheers,
If they do the job right then it costs what it costs. Engine reconditioning soon adds up !
Indexing is where they'll phase the crankpins to get them all truly at 00 and 1800. The standard production tolerances can have them out from that.
PS the actual standard size of the Crankpins is 1.6254" to 1.6259".. The Mains are 1.7505" to 1.7510".
The measurement you have there looks like it's bang on 1.6250", though, that's only a measurement in one place. The 1098's I find wear more on the Mains than the Crankpins.
#6 babsbrown
babsbrown
  • 459 posts
Posted 16 November 2024 - 06:24 PM
Cheers,
Thanks mate, haha to be honest I haven't used a micrometer since engineering class at school haha. I measured the big ends and they're 1.7510. Maybe I can get away with a polish.
Cheers for the information im learning heaps as I build this engine.
#7 weef
weef
  • 489 posts
Posted 17 November 2024 - 12:07 AM
Before taking any mearurements you have to ensure your micrometer is calibrated and within spec.
Crankpins have to be measured for both taper and roundness,
Generally 0.004" is the maximum undersize from the design minimum dimension, then a regrind to the next preferred journal size is required.
From your picture your measurement appears to be at the maximum limit, perhaps it may be worth getting your shaft measured at a machine shop.
#8 Mr Piggy
Mr Piggy
  • 50 posts
Posted 17 November 2024 - 08:33 PM
5 thou is way too much wear and you'd have very low oil pressure. I'd regrind a crank that measured 0.001" under spec.
#9 ings
ings
  • 201 posts
Posted 18 November 2024 - 10:04 AM
After grinding, the crankshaft should ideally be hardened, as the grinding process reduces its hardness.
#10 sonscar
sonscar
  • 2,997 posts
Posted 18 November 2024 - 04:02 PM
And after hardening it you need regrinding to correct potential distortion?Not all steel is capable of meaningful hardening is my understanding.Just my thoughts,Steve..
#11 Spider
  • 14,849 posts
Posted 18 November 2024 - 05:05 PM
These cranks aren't surface hardened at all.
You could have them tuftrided, however, there's no advantage in a road car.
#12 babsbrown
babsbrown
  • 459 posts
Posted 25 November 2024 - 04:23 PM
Thanks guys after a bit of thinking I reckon I'll take it for a regrind.
#13 Earwax
Earwax
  • 487 posts
Posted 25 November 2024 - 10:49 PM
I would take the crank to your trusted machine shop, take your reference measurements and also ask them to check what their reference measures are. Then they will decide - this will hopefully avoid bearing spinning or a regrinding if unnecessary.
( I do not trust my micrometer readings on things like cranks and rods) ( PS do your conrods need closing?)
#14 babsbrown
babsbrown
  • 459 posts
Posted 26 November 2024 - 05:28 AM
Thanks mate, I'm not sure what conrod closing is?
#15 Shooter63
Shooter63
  • 1,027 posts
Posted 26 November 2024 - 06:30 AM
What Earwax means is big end re-sizing, where the machine shop grinds a small amount off the conrod thus allowing them to hone the big end back to the correct size for bearing fitment. Where abouts in the country are you? This will allow people to suggest decent machine shops.
Shooter
