5As Programming
1 reply to this topic
#1 Deeppockets
Deeppockets
  • 98 posts
Posted 12 November 2024 - 01:08 PM
For those who have not been following Andrew Revill's work on MEMS and 5AS, he has published s/w and a relatively simple cable spec to programme a 5AS without removing the ROM.
andrewrevill.co.uk/MEMS3LucasImmobiliserSupported.htm
In addition to adding/changing the key fobs it also allows ECU pairing and other options. Using an old VW KKL cable and OBDII Y cable from the my hoard of stuff in the cupboard I had it working in a couple of hours.
Great work Andrew!
I can now complete my slow-burn project to replace the single connector 5AS with a later dual-connector version to flash the indicators on lock/unlock, finally install central locking and also install the fob energiser coil into the steering column cowling for automatic disabling the immobiliser. ("This occurs automatically whenever the key is inserted into the starter switch and turned to position II provided the handset is in close proximity to the switch.")
I have had this on the bench for a few years but had not means to change the MEMS pairing code.
#2 Bobbins
Bobbins
  • 1,462 posts
Posted 12 November 2024 - 04:26 PM
A few years ago Andrew drove a couple of hours from his home in the Midlands up to Warrington to program some 5AS key fobs for us, he's a great guy and will go to massive lengths to help people.
He's done a lot of work with the MEMS ECUs fitted to Caterhams and if I recall correctly has completely mapped ('scuse the pun) what the units do to enable them to be reprogrammed, I must admit that 99% of it goes completely over my head!
