Installing Front Brake Shoe Retainer Springs (27H3753)
brakes
Best Answer Spider , 19 November 2024 - 05:50 PM
The factory recommends replacing all rubber parts, including the hoses, of the Brake system every 3 years or 40,000 miles. While that's the factory advice, I do mine about every 4 - 5 years.
The Hoses perish from the inside, it's difficult to assess them from the outside. If you don't know what the history of them is, I would recommend replacing them.
While I love the look of braided hoses, I don't fit them as they are even more difficult to assess the condition of and also can't be crimped off without damage to isolate a Brake when doing maintenance.
Go to the full post
11 replies to this topic
#1 dschwartz1957
dschwartz1957
  • 44 posts
  • Local Club: New England Mini Owners (NEMO)
Posted 08 November 2024 - 02:49 AM
My 1968 Mini Traveller had braking problems for much of the summer driving season. I needed to pump the brakes 2 or 3 times before there was good pedal pressure, even though the fluid level in the master cylinder stayed constant. Adjusting and bleeding the brakes did not eliminate the problem, and I was unable to get the left front and left rear wheels to fully lock. I removed all four drums to investigate.
The left rear brake adjusters were worn and small chunks of metal were missing. I plan to replace the adjuster and wedges with http://www.minispare...ic/17H7620.aspx The rear shoes were replaced 12 years ago and have over 4 mm of friction material remaining.
The left front shoes were worn to 1.98 mm and 2.3 mm. The right front shoes were around 2.6 mm. The front pads and wheel cylinders are 14 years old, and two cylinders had a tiny amount of fluid under the boots, and some staining on the backplates. I plan to replace all four wheel cylinders and both sets of shoes.
The Mini Spares parts diagram shows a "front brake shoe retainer spring", which my car never had during my ownership. The part is required with the 0.9375" bore size wheel cylinders (GWC126 / GWC127) which I plan to install. http://www.minispare...ck to catalogue
I have read through the Haynes Manual and the Mini Workshop Manual and can't figure out how the little retainer springs are installed. The photo on the Mini Spares link I posted shows the spring going through a hole in each brake shoe just below the wheel cylinder piston, but the details are obscured by a logo watermark. The photo is attached below for your convenience.
Does anyone have a picture or good diagram they can post showing how the retainer springs are installed?
Thank you,
David Schwartz
Framingham, Massachusetts
Edited by dschwartz1957, 08 November 2024 - 02:52 AM.
#2 Spider
  • 15,861 posts
Posted 08 November 2024 - 05:23 AM
I don't seem to have a photo or diagram that shows how they are when fitted, but they are quite straightforward to fit up. These are of course, for Twin Leading Shoe Brakes, which your 68 Traveller should have.
With them missing, that could well be part of the issue you are having with the need to pump to get a peddle. The adjusters in these Brakes move and hold the Cylinder end of the shoes out to a point just on drum contact. Because they are adjusted at that point, the Pistons in the Wheel Cylinder also need to be held resting on the frame of the shoe. Without something in there to pull and hold the Piston in contact with the Frame of the Shoe, the Pistons, particularly those on the Trailer side, will self retract back in to the Cylinder, especially with road vibration. The other item that maybe missing is a Residual Pressure Valve, these are inside the Master Cylinder and retain around 5 - 10 PSI in the system to also assist with keeping the Pistons held out in all Wheel Cylinders.
#3 Lplus
Lplus
  • 1,004 posts
Posted 08 November 2024 - 07:16 AM
Thank you,
David Schwartz
Part no 27H3753 on the minispares site.  The blurb even mentions having to pump the pedal.  They are installed in the shoe before fitting, Hook the large hook throught the hole in the shoe, from the backplate side,  pull the small tang through the hole as well and twist the big hook away from the end of the shoe for fitting.  When the shoes are in place, twist the hook back round, pull out whilst holding the shoe against the backplate and insert the end of the hook in the hole in the piston
edit - one other thing to check is that the adjusters are stiff in rotation enough to hold the shoes close to the drums against the long springs pull.
Edited by Lplus, 08 November 2024 - 07:21 AM.
#4 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 11 November 2024 - 08:46 PM
My experience with drum brakes all round is you really need to start with a new, adjusted and optimised system if you want them to work. Once mine were sorted the pedal was firm from the top, and an emergency stop would lock both fronts evenly
Make sure all the wheel cylinders move freely and aren’t seized. Replace all the old rubber brake hoses. Replace all the shoes with new ones and make sure the drums aren’t worn oversize. Adjust the drums (with the front end rotate the adjusters tighter in the direction the wheels spin when going forward) tight enough so the wheel will do less than one spin freely before stopping. Press the pedal down a few times then adjust again once the shoes are centred.
#5 dschwartz1957
dschwartz1957
  • 44 posts
Posted 19 November 2024 - 05:36 PM
I just received a big order from Mini Spares containing: the front brake shoe retaining springs that started this post, front and rear wheel cylinders, front brake shoes (the rear are 4+ mm), front and rear springs (the old ones are quite rusty), rear brake adjuster and tappets kits, handbrake lever gaitors, some replacement hard lines, and misc. hardware. Where applicable, parts are "genuine AP".
I debated replacing all the rubber hoses, but they are still flexible and don't have any cracks. Am I making a mistake by not replacing them while doing a major brake job?
Is it preferable to go with the braided hoses? Rubber are much less expensive?
http://www.minispare...|Back to search
Edited by dschwartz1957, 20 November 2024 - 09:42 PM.
#6 Spider
  • 15,861 posts
Posted 19 November 2024 - 05:50 PM   Best Answer
#7 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 19 November 2024 - 09:11 PM
Do the hoses now while you have brake fluid everywhere. And don’t forget the copper washers!
It’s also easier to put the new rubber hoses on the front brake assembly first, then attach the rubber hose to the subframe and hardlines.
#8 Lplus
Lplus
  • 1,004 posts
Posted 20 November 2024 - 02:02 PM
It's actually important to do it that way round so the hoses are properly sealed tightly to the cylinders and thus don't need twisting to get them tight if they've been fitted to the subframe first.
#9 dschwartz1957
dschwartz1957
  • 44 posts
Posted 02 May 2025 - 01:41 AM
Now that the weather is good, I am finally working on my Mini again. Attached is a photo showing the fitted retainer springs. To install them, I used a large screwdriver to lever the brake shoe away from the wheel cylinder and inserted the hooked end through the hole in the shoe. I fit the spring into the small hole in the wheel cylinder before fully engaging the brake shoe in the slot. It was definitely a fiddly job.
Edited by dschwartz1957, 02 May 2025 - 01:44 AM.
#10 Spider
  • 15,861 posts
Posted 02 May 2025 - 06:42 AM
Looks good !
#11 Steam
Steam
  • 965 posts
  • Local Club: Victorian Mini Club
Posted 02 May 2025 - 07:22 AM
Don't forget that the shoe position is vitally important with left and right being mirror images. Also the spring placement, particularly at the rear is also essential.
#12 Mr Piggy
Mr Piggy
  • 71 posts
Posted 02 May 2025 - 07:20 PM
Also note that the front adjusters are turned in the forward direction of wheel rotation to tighten them. So looking from under the car the right hand adjusters go anti clockwise, the left side go clockwise. I used to see a lot of minis where both sides were adjusted clockwise, as on the back. So the r/h front didn't work properly, wore the shoes at one end and the brakes pulled to the left.
