Access To Tower Bolt On 2000 Mpi
Best Answer MagnumMPI , 06 November 2024 - 05:40 PM
Thanks for advice.
Removal of the purge valve and some brute force to remove the wiper motor cover did the trick.
Go to the full post
3 replies to this topic
#1 MagnumMPI
MagnumMPI
    Starting My Mini Up
  • 2 posts
Posted 03 November 2024 - 01:52 PM
Trying to change the front cones on my 2000MPI. The drivers side tower bolt is easy to access and 1" 5/16 socket removed without issue. The passenger side however seems impossible to access, there is not even enough space for the socket to get through between the wiper motor & the 45Deg bulkhead.
Any clever ways to do this without removing the expansion tank, purge valve & wiper motor ?
#2 Steve220
Steve220
  • 5,146 posts
  • Local Club: BMC
Posted 05 November 2024 - 04:52 PM
Remove the wiper motor.
#3 Rubbershorts
Rubbershorts
  • 743 posts
Posted 05 November 2024 - 05:08 PM
.....or just the wiper motor cover? Might just give you enough room.
#4 MagnumMPI
MagnumMPI
    Starting My Mini Up
  • 2 posts
Posted 06 November 2024 - 05:40 PM   Best Answer
Thanks for advice.
