Scuttle Unused Holes - Weld Up?
10 replies to this topic
#1 T1m
T1m
  • 15 posts
Posted 24 October 2024 - 06:31 PM
Hi guys
Replacing the scuttle and seen a few people weld up the unused holes. Anyone have any view whether to weld up or not? Thanks!
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,998 posts
  • Name: Neil
Posted 24 October 2024 - 07:27 PM
Weld them up as they are superflous.
#3 Midas Mk1
Midas Mk1
  • 5,749 posts
  • Local Club: S.U.N.M.C
Posted 24 October 2024 - 07:36 PM
Welded mine up, blanking plugs just don’t look nice to me (imo)
#4 T1m
T1m
  • 15 posts
Posted 24 October 2024 - 08:24 PM
Cheers guys. That’s decided. Will weld them up. Thanks.
#5 IronmanG
IronmanG
  • 1,212 posts
  • Local Club: Box hill. Lsmoc member
Posted 24 October 2024 - 09:31 PM
Yep mine welded
#6 Bobbins
Bobbins
  • 1,464 posts
Posted 25 October 2024 - 06:37 AM
Funny old world, phrase the question differently and you’ll be told that for originality you should keep them!
#7 T1m
T1m
  • 15 posts
Posted 25 October 2024 - 08:35 AM
That’s what I was mentally wrestling with. Originality vs do it once.
#8 stuart bowes
stuart bowes
  • 1,942 posts
Posted 25 October 2024 - 08:38 AM
well it's easier to make holes than it is to fill them in, especially when it's painted ..  fill em in, paint it, later on if you're feeling really pedantic and you need to use a hole cutter it's easy
#9 T1m
T1m
  • 15 posts
Posted 25 October 2024 - 09:24 AM
Great idea. Had not thought of that. Thanks!
#10 Designer
Designer
  • 529 posts
  • Local Club: 8 Iron
Posted 25 October 2024 - 12:14 PM
Hi,
If doing as Stuart suggests make sure you measure position of existing holes.
May I suggest you get  a peace of suitable paper that covers all four holes then rub a pencil over the paper which will the highlight where the holes are. ( Like a brass rubbing)
Then if you want to redrill the holes you can line up the paper with the remaining two holes and that will fix the position for the two to be drilled again.
Paddy
#11 stuart bowes
stuart bowes
  • 1,942 posts
Posted 25 October 2024 - 12:17 PM
good call
and don't weld up the wrong ones by mistake
