Winter Lay Up
3 replies to this topic
#1 colinspeight
colinspeight
  • 11 posts
Posted 14 October 2024 - 03:53 PM
That's it then, sid the mini all off the road now till next spring on SORN, under cover and dust sheeted, battery on trickle and now avoiding all that nasty salt n stuff.
Roll on March!!!
#2 mab01uk
mab01uk
  • 12,239 posts
Posted 14 October 2024 - 04:13 PM
One of the advantages of the sealed fuel injection system on later Minis is any petrol left in the tank takes a lot longer to go stale during a winter lay up, although the increasing Ethonol content of modern fuels can cause corrosion problems and cause leaks in old spec flexible fuel pipes. Ideally add some STA-BIL Storage Fuel Stabilizer.
Edited by mab01uk, 14 October 2024 - 04:15 PM.
#3 colinspeight
colinspeight
  • 11 posts
Posted 30 October 2024 - 04:56 PM
Thank you there is only about 5 litres of e10 in the tank, if I put 15l of E5 in will that suffice
#4 Midas Mk1
Midas Mk1
  • 5,741 posts
  • Local Club: S.U.N.M.C
Posted 31 October 2024 - 07:28 AM
Id be worried of your rubber fuel lines if you've been using e10, even with e5 I had serious cracking on my MPi after being on for a year. Perfect time to check and replace if needed to ethanol resistant lines.
Doesnt really change things being a sealed system, ethanol will still attack components such as injectors, fuel pump etc, best to run stabiliser if stored, with e5, and make sure its mixed and ran so in the system.
