Are the engine braces polybushed as well top and bottom?
Poly top and bottom.
Best Answer Rubbershorts , 18 October 2024 - 05:54 PM
Cracked it. Cheers everyone, the vibration that was spoiling our enjoyment of the car has greatly reduced. I can now see everything in the rear view mirror. It's not modern car smooth but I can now concentrate on the other things that wind me up as the engine mounts and tie bar mounts problem was masking them somewhat. Exhaust is blowing and causing the car to run rough, and I can't seem to locate what is causing the speed wobble. Bits for the stage one conversation have arrived to sort the first issue, and I think a trip to the wheel balancer ( with brand new wheel/ tires that were already balanced) is on the cards.
Go to the full post
Posted 13 October 2024 - 07:06 PM
Posted 13 October 2024 - 07:17 PM
Does this vibration match engine revs? or is it only road speed dependent when it's occurring?
Posted 13 October 2024 - 07:33 PM
Posted 14 October 2024 - 05:16 AM
Posted 14 October 2024 - 06:28 AM
Have come across some horrible engine mounts that are like the engine is solid mounted, replacing with some decent ones transformed the car.
Posted 14 October 2024 - 06:51 AM
Its had a new subframe with a previous owner and the upper mounts were changed to poly. Hopefully at the same time they put something solid in for the engine mounts and just changing them will calm everything down. Is it possible to see engine mounts without taking anything out of the car? Radiator etc?
Posted 15 October 2024 - 10:54 AM
You should be able to see the mounts from under the front or through the grill aperture. I'd expect an engine or driveline vibration to transmit whether the clutch was in or out, but since you say it only occurs with the clutch in I'm wondering if the problem is some sort of misalignment in the flywheel/pressureplate/clutch plate area.
Posted 15 October 2024 - 11:24 AM
Its had a new subframe with a previous owner and the upper mounts were changed to poly. Hopefully at the same time they put something solid in for the engine mounts and just changing them will calm everything down. Is it possible to see engine mounts without taking anything out of the car? Radiator etc?Have come across some horrible engine mounts that are like the engine is solid mounted, replacing with some decent ones transformed the car.
Posted 15 October 2024 - 12:13 PM
My second suggestion was going to be an out of balance clutch and flywheel. If it has had a new clutch fitted there's a good chance whoever did it didn't get it balanced which is vital, particularly on a verto setup.
Posted 15 October 2024 - 12:43 PM
If I'm sat in the car revving it, it is so loud and noisy with the vibrations. That is regardless of whether the clutch is engaged or not (so stationary). If outside the car, either reaching in and revving by means of the throttle on the carb, or if the car is driven past you, it sounds sweet. Flying downhill the car vibrates like hell in gear. Knock it out of gear and it's a smooth magic carpet ride. Does this reveal anything?
Posted 15 October 2024 - 04:37 PM
Your engine is touching something,look carefully.This has the benefit of being free.Steve..
Posted 15 October 2024 - 05:07 PM
Edited by Rubbershorts, 15 October 2024 - 05:07 PM.
Posted 15 October 2024 - 09:03 PM
Posted 15 October 2024 - 09:07 PM
Posted 16 October 2024 - 06:41 PM
