Engine Not Running Correctly
Best Answer lsto , 04 October 2024 - 05:01 PM
It looks like you have left the breather connection on the carb open. This needs to either be connected to the engine breather pipe or blocked off. Go to the full post
Posted 02 October 2024 - 10:34 PM
Any other suggestions of what could be causing this would be greatly appreciated. I have a video of it if anyone wants to see if I’ll hopefully be able to send it, if not I’ll put it on YouTube and share a link to it. At the end of the video I turn the ignition off and it continues to run afterwards which it hasn’t done before either. Just for a bit of context the engineering question is a 1380 with HIF 44 manifold, maniflow Stainless exhaust, Evolution, two camshaft and high lift roller rockers.
Posted 02 October 2024 - 11:18 PM
Start with the ignition system. Don't touch the carb/fuel system until the ignition system is perfect unless there's an obvious fault like fuel leaking. Your "flooding" issue may very well be an ignition fault.
Check the points, condenser, rotor, cap, leads and coil. Don't replace them unnecessarily though, there's too many rubbish parts sold. Is the coil correct? Is there excessive voltage drop?
Once those are all checked and fixed, check the ignition timing throughout the rpm range.
Only once the ignition system is confirmed to be perfect do you move to the carb/fuel system.
Checking the fuel system. For a start, please upload some photos of the engine bay and carb for us. Often the carb has been connected incorrectly and wastes a lot of time.
IF the carb is connected correctly then proceed. Adjust the idle speed to the specification. Now adjust the idle mixture, there's only one mixture adjustment screw and it's for the idle. If you are running lean/rich above idle, you either have an issue or the needle/spring needs to be changed.
Edited by 68+86auto, 02 October 2024 - 11:20 PM.
Posted 03 October 2024 - 10:22 PM
If it has been sitting for a while, the bob weights at the base of the distributor may be sticking. Clean them with brake & clutch cleaner and lightly re-lube with 3-in-1 oil.
It may not be that, but it's well worth checking.
Posted 04 October 2024 - 12:36 PM
Posted 04 October 2024 - 02:15 PM
Have you fresh fuel in the tank ?
Posted 04 October 2024 - 05:01 PM Best Answer
Posted 04 October 2024 - 09:31 PM
Posted 04 October 2024 - 09:33 PM
Unfortunately not. I put some petrol in a Jerry can about a year and a half ago. It was e5 super unleaded and I didn’t think it would cause that much of an issue, but again it’s definitely worth a try
Posted 10 October 2024 - 11:25 AM
Exactly.
It's why I ask for pictures.
Posted 12 November 2024 - 04:43 PM
