Posted 02 October 2024 - 02:08 PM
Posted 02 October 2024 - 04:06 PM
What does the hub look like ?
Posted 02 October 2024 - 05:06 PM
Looks like its been rubbing on the swivel hub ? incorrect spacing
Posted 02 October 2024 - 06:33 PM
It's worn out !
The Wheel Bearing has been rubbing on it for quite a while from the nut on the CV not being tight enough. The split type tapered washer that sits behind the nut doesn't help either.
Some more reading here;-
https://www.theminif...wheel-bearings/
Posted 04 October 2024 - 06:34 AM
You'll need to change the CV as the spline will be knackered, the tapered washer, and the wheel bearing too...
Posted 13 October 2024 - 02:57 PM
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Handbrake Plate And Sealing PadStarted by dschwartz1957 , Today, 01:07 AM ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 ![]() |
![]() Installing Front Brake Shoe Retainer Springs (27H3753)Started by dschwartz1957 , 08 Nov 2024 ![]() |
Is It Easy To Swap Post 84 Drums To Pre 84 Drums?Started by Daniel Watkin , 03 Aug 2024 ![]() |
